Old 10-11-2011, 09:40 PM   #1
kcfirstbuild
Stripped bolt hole in balancer.
I did NOT strip the crank, but one of the three the bolt that hold the pulleys on. I'm going to try and run a 3/8-24 tap through to clean it up, but if that doesn't work.
Since I still have two good 3/8 holes and the crank bolt / larger washer will i be ok not using the third 3/8 stripped hole. Or will that mess up the balance?
Could i use a smaller bolt and nut it on the back side?
Last result is heil coil it, its just in a horrible place.
kcfirstbuild is offline   Reply With Quote
Old 10-11-2011, 09:45 PM   #2
Hubscrub
Cruzin
Hubscrub's Avatar
Re: Stripped bolt hole in balancer.
I was going to recommend a heli coil, i have used them with great success. i used one awhile back on a outer head bolt with no problems.
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 10-11-2011, 10:06 PM   #3
bigsnookmaster
bigsnookmaster's Avatar
Try a longer bolt in all three holes, just check to see if it comes too far out the other side. Sometimes you might have extra thread past the stripped area. .02
bigsnookmaster is offline   Reply With Quote
Old 10-11-2011, 10:14 PM   #4
kcfirstbuild
i cranked on it and it messed it up good
Old 10-11-2011, 10:44 PM   #5
mcbassin
Still Learning
mcbassin's Avatar
Use a heli-coil. Or you could do like BigSnook said and try a longer bolt. Maybe you could tap it a little
deeper with a standard 3/8-24?
Old 10-11-2011, 10:49 PM   #6
stealthy '69
'69 Chevy SWB
stealthy '69's Avatar
wouldn't the weight difference of the heli-coil affect the accuracy of the balancer? If you plan on reusing the balancer I would think it would throw it off a little. if you are replacing it with a new one, then yea I'd say a longer bolt or heli-coil. That's just my thoughts though.
Matt
'69 Chevy SWB Fleet, Primer Black; Project No Name
'06 Chevy Trailblazer, Blueish Silver?; Wifes DD, Sold
'08 Chevy Impala SS, Silver; the new DD, AND IT IS FUN!!!
'99 Dodge Dakota R/T, Intense Blue; DD, Sold
Originally Posted by longbed67 View Post
The tig welds are not the prettiest i have seen but they do have good penetration.
Originally Posted by oldblue1968chevy View Post
There are two things in life where penetration is really important.....and one of them is welding.
stealthy '69 is offline   Reply With Quote
Old 10-11-2011, 11:12 PM   #7
kcfirstbuild
Its a brand new balancer, that I missed up. So don't really want to remove it and throw it. How bad would it throw it off if i put a longer smaller bolt with a nut on the back side ?
Old 10-11-2011, 11:56 PM   #8
kcfirstbuild
Other advice ?
Old 10-12-2011, 12:51 AM   #9
RustyBucket
RustyBucket's Avatar
a helpful guy in the fastener supply business MIGHT just be able to tell you that there is a metric bolt the right diameter to fit the damaged hole. You might have to pass the right size drill bit and then tap it with a metric tap. I've stripped treads in some Jap motorcycle stuff and tapped it to S.A.E. ..... didn't even have to redrill it. 'Course it WAS in aluminum. GOOD LUCK!
Dad always said, "Son, WISH IN ONE HAND, and ......."
Current toy trucks:
'71 GMC 1500 SUPER CUSTOM short/step, orig. dk. blue, 350/700r, ps,pb, A/C
'72 Blazer 2wd, ochre & white, 454, tremecTKO 500 5spd. ps, pb, A/C, tilt
Last 10yrs of hobby vehicles, had a FEW more in the 50yrs. before these:
'66 Plymouth Belvedere City of Miami cop car clone.
'70 Nova 406"sb, 13.5-1, solid roller, Brodix, p.glide/t.brake, back halved, 9" Ford, spool 4.88, cage,ladder bar/coilover, 10.5 tire....... SOLD!!
'67 C10 short/step side mount spare -- SOLD!!
'72 Jimmy 2wd, 350/350, ps, pb, fun driver, lots of bondo & a shiny red paint job..... SOLD!!
'69 Nova 350, 4spd, A/C, ps, p.b, ...SOLD!!
RustyBucket is offline   Reply With Quote
Old 10-12-2011, 08:38 AM   #10
kcfirstbuild
I thought of that in my sleep. I should be able to figure that out at work, what the next metric size is.
Old 10-12-2011, 08:57 AM   #11
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
A simple Dual system (Metric/SAE) bolt guage is $2-3 most places and can help in these problems.I have several and even keep one in my JYing toolbox.Get the one that has pegs for the nuts on the outside.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 10-12-2011, 09:51 AM   #12
MARKDTN
No way I would bolt and nut on the backside. This is a balanced part. If a helicoil won't work, I would get a new one. They are not that expensive.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 10-12-2011, 01:45 PM   #13
TobyArnot
Quit if it's not FUN!!!
TobyArnot's Avatar
Put a Heli-Coil in all three holes. No Foul!
TobyArnot is offline   Reply With Quote
Old 10-12-2011, 01:58 PM   #14
john
member #16
john's Avatar
Good advice.
john is offline   Reply With Quote
Old 10-12-2011, 03:18 PM   #15
hayhauler71
hayhauler71's Avatar
drill all three and retap all three with all the same bolts done
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 10-12-2011, 04:02 PM   #16
DorianB
DorianB's Avatar
You should be able to run the right size bolt through the back of the balancer and it may help clean out the threads so you can get the bolt going in correctly. (Don't ask me how I know this, but it does work )
DorianB is offline   Reply With Quote
Old 10-12-2011, 08:05 PM   #17
stealthy '69
'69 Chevy SWB
Am I wrong in assuming the 3 bolt holes are for installing/removing the balancer? It's been a long time since I had to mess with one. If that's the case then I would think a bolt all the way through and remove it when you're finished, would work ok.
Matt
Old 10-12-2011, 08:14 PM   #18
kcfirstbuild
all fixed up ! I ran a 3/8 24 tap through it cleaned up the first couple threads. I did get a longer bolt cause i did notice the threads near the end of the hole were still good like you said. So presto ! All done !
Old 10-12-2011, 10:46 PM   #19
mcbassin
Still Learning
mcbassin's Avatar
Good job! glad that worked out for you. If you were worried about it causing balance issues, you could chase all three deeper and use the same length bolts on all three.
Old 10-12-2011, 08:16 PM   #20
stealthy '69
'69 Chevy SWB
cool glad you got it all fixed up. I just went out and looked and realized they bolt holes are for the pulley too. DUHH!!
Matt
