10-13-2011, 12:50 PM | #1 |
Active Member
Stripping tint film from windows
If I use mineral spirits to strip all the 1980s tint film from my windows will it hurt or remove the factory tint?
Is there a better way to strip old tint? |
10-13-2011, 01:12 PM | #2 |
Re: Stripping tint film from windows
The factory tint is part of the glass. You can't hurt it.
I use a razor blade scraper to remove window film. Use some glass cleaner on the glass in front of the blade to lubricate it and keep the film from sticking to it. |
10-13-2011, 01:13 PM | #3 |
1969 Custom 30 wrecker
Been a long time but I recall peeling it off (and it stinks when you do that!) and just soaking the adhesive with Windex and using a razor blade. Should come right off.
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
10-13-2011, 01:32 PM | #4 |
Mineral spirits shouldn't hurt the window but it might hurt the gasket. I used a razor blade to do mine as well.
10-13-2011, 01:41 PM | #5 |
I've heated the old tint up with a hair dryer or heat gun first, it separates better. The adhesive that's left over use a razor blade.
10-13-2011, 02:23 PM | #6 |
English Chevy Owner
I pulled the old stuff off mine, most came off in big strips but on the rear windows I had to use a razor blade to scrape it off. I then used cellulose thinners to strip the glue off.
Phil '67 C10 long fleet. 350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon 2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission |
10-13-2011, 02:26 PM | #7 |
Use ammonia in a well ventilated area. Will disolve the adhesives. Should be a minimal amount of scraping required.
JB from AZ 1969 Chevy Sub K10 1957 Chevy 3200 1962 VW Beetle 1957 Willys CJ5 |
10-13-2011, 03:27 PM | #8 |
X2 on the ammonia.
10-13-2011, 03:49 PM | #9 |
Do this in the shade
If you don't have defroster worse in window. Score with a razor blade mor the better We spray the window with soapy water. Then we stick newspaper to the wet window. And keep soaking paper to keep it wet. Paper help keep it wet to soak into tint. Then start peelin and peelin and peelin Very stinky Posted via Mobile Device |
10-13-2011, 04:17 PM | #10 |
Newbee
X3 on ammonia! Window tint companies say not to use ammonia based cleaners for a reason.
May want to use a respirator when you do it. |
10-13-2011, 04:34 PM | #11 |
you can buy glass cleaner with ammonia in it at the parts store. Works very well.
1972 Custom Deluxe LT1 Gen V Swap "Green Lantern" 1984 Silverado Red Baron-72 c10 Project |
10-13-2011, 05:36 PM | #12 |
Active Member
Thanks for all of the tips, The windows are all out of the truck its a total restoration.
I want to use all of the original soft ray tinted glass but use new glass for the windsheild. |
10-13-2011, 08:12 PM | #13 |
Devil's in the Details
I've peeled it off by hand before, then used Simple Green to dissolve the remaining adhesive and a razor blade to finish the job.
'70 K10 Suburban - TBI 454, 4L80E, NP241C, Dana 60 & 44 - The 10+ Year Project Thread Datsun 240Z, 510 2 door and an old Honda motorcycle |
