10-14-2011, 12:16 AM | #1 |
c20 suspension recap?
hello everybody another newbie here, found this site the other day and have been reading ever since! awesome site-so much information its unbelieveable and everyone seems so happy to help! its very appreciated!!
my question is this- i just got a 1968 c20 with rear leafs, 8 lug, manual steering and brakes. from what i gather and excuse me if this incorrect- the front suspension from a 73-87 1/2 ton chev or gmc truck/van will bolt in place to get 5 lug bolt pattern,front disc power brakes? also i can use the booster and master and the p/s parts? the rear diff will be wider by about a inch and a half and will need new perches welded on with a 2 or 3 degree down pinion angle? last ?? i was thinking of using the 5" lowering leafs from early classics, has anyone used these? good or bad?? thanks for the help!!! |
10-14-2011, 01:00 AM | #2 | |||
Re: c20 suspension recap?
10-14-2011, 01:11 AM | #3 |
thanks for the reply good point about the axle flip i guess that slipped my mind. my hope is to get a donor truck and get all my parts in one bunch, hopefully will be a winter spent in my garage!!
if i did the axle flip--if i weld the perches parallel to the original ones i'm thinking my i wont have enough pinion angle?(probably be around 0 deg.) or would it stay the same? Last edited by 1968robinsegg; 10-14-2011 at 01:19 AM. |
10-14-2011, 01:26 AM | #4 | |
10-14-2011, 02:27 AM | #5 |
sorry everybody i see now going farther back this has been talked to DEATH!!!
thanks for the help and patience though!! |
10-14-2011, 03:55 AM | #6 |
67-72 parts collector,…
Welcome to the board!
There are quite a few subjects that get "talked to death". But that's why we are here. Keep us posted on your project,... and remember,... we like pictures! Ha.
