Dropmember and turning
So I ordered a drop member for my blazer and I was wondering for those you guys running one is, since the crossmember narrows the track width can you make turns with the tire and wheel still tucked in the fender.
I am running a 15x7 wheel with a 235/60/15 tire with like a 3.5" backspacing. Later, on I'd like to run a 20x8 wheel with a 255/35/20 and a 4.5" backspacing. However, I don't want to have to air the truck up to the point it looks like a donk when I drive down the road. |
A guy with a truck
Re: Dropmember and turning
You will be able to turn lock-to-lock at ride height (~6"), tires/whels tucked, without airing up 'donk style'. The trade off here is that the rack & pinion doesn't turn as tight as your current box, so the wheels don't contact the fenders...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
#3 | |
When I drove it down the block with my son this is where we had the ride height. ![]() Last edited by Rochlow; 10-14-2011 at 03:00 PM. |
Back needs to be lower
Posted via Mobile Device |
Looks great! Kinda makes me want to give up on my shortbox project and use all the goodies on my blazer instead
![]() Posted via Mobile Device
--------------------------------------------------------------- Jason. 68’ GMC shortbox https://67-72chevytrucks.com/vboard/...d.php?t=794201 72' 2WD Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=425385 67' LongBox C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=691845 InstaGram ybnorml67 |
#8 | |
![]() Join Date: Sep 2008
Very nice!!! I am building a blazer now. Where did you mount your air tanks and what size are they?
3 gallon under the body behind the rear wheel.
Village Idiot....
This is where I'm driving at the moment, you have to be careful turning sharp corners or it will "touch" the fender. I have driven it lower but at this height I can drive it without to many worries. Hope this helps you....
http://67-72chevytrucks.com/vboard/s...351837&page=44 post 1092
http://www.hubgarage.com/mygarage/n2billet -67 SWB Custom Porterbuilt Front and rear 20/22's Hazel Sold -71 StepSide Porterbuilt Stage 2 with 20/22's Stella Mae Sold |
#12 | |
#13 | |
needs more $$$
1970 2wd Blazer |
#14 | |
Village Idiot....
It rides awesome! I don't know the PSI, I'm using AccuAir and the system doesn't use gauges.
