10-16-2011, 04:40 PM | #1 |
SSN 706
power brake booster on s10 layin frame.
I have a 52 on a s10 frame. I want to put my booster and brake stuff on the frame. I'm worried that I won't have room to run my exhaust and still lay frame. Any pictures or help from someone who has done this would be greatly appreciated.
10-16-2011, 07:42 PM | #2 |
Re: power brake booster on s10 layin frame.
Here is one more option for you we have our under the dash pedal assy that will work great in your truck.
Justin |
10-16-2011, 08:15 PM | #3 |
SSN 706
Where's that. I want it.
10-16-2011, 08:20 PM | #4 |
Sorry about that go to our web www.scottshotrods.com. And when you are on the front page go to our links on the left hand side of the page you will see under scotts parts under the dash pedal assy and if you are interested in our product send me a e-mail at
Justin@scottshotrods.com and we give you a great deal on it and I have several in stock so shipping will be fast. Justin Posted via Mobile Device |
10-16-2011, 08:27 PM | #5 |
SSN 706
Thanks Justin. One more? if I have disk/disk do I need a booster?
10-16-2011, 08:31 PM | #6 |
That is up to you if you want power brakes or not.I have a 67 c-10 with 4 wheel disc running 14 inch rotors and 6 piston cslipers running a wilwood manual master stops great.
10-16-2011, 08:36 PM | #7 |
SSN 706
Email sent. Thanks Bud.
10-16-2011, 08:41 PM | #8 |
10-16-2011, 08:43 PM | #9 |
SSN 706
I wish I had brakes like that. Mines just s10 stock in the front and the back is a zr2 s10. Just sent it.
10-17-2011, 09:54 AM | #10 |
any pictures?
10-17-2011, 01:34 PM | #11 |
SSN 706
Just click on my build site for my 52 where it says "Click it"". Lots of pictures.
10-17-2011, 02:49 PM | #12 |
I run a booster on my disk/disk. but Im lazy haha. as little effort as possible. If I get excited and mash the pedal I will go through the windsheild.
10-17-2011, 04:11 PM | #13 |
SSN 706
I'm going to run a booster. When I was thinking about putting it on the frame I thought no booster might give me alittle more room to run my exhaust. Lazy makes 2 of us.
10-18-2011, 08:10 AM | #14 |
a hydroboost is smaller then most brake boosters... more reliable then the small aftermarket boosters too...
will the exhaust still fit by? eh, its tight. you can either make it work, or go around under the oil pan and have both exhausts on the other side of the truck (like a 3rdgen camaro) |
10-18-2011, 11:28 AM | #15 |
On mine, I used a X pipe and I think going that route you would have plenty of room to fit a small booster set up. Sorry that I don't have a good left side picture for you see. And I looked throught to build but didn't see a picture of how your set up is for placement of your cab and such. My running boards are quite lower than my frame so if I was layin frame they would hit first and the actual S10 frame never touch pavement allowing room to fit your exhaust.
Best of luck. |
10-18-2011, 01:23 PM | #16 |
SSN 706
My frame hits just before my running boards hit. I decided to go with the ounder dash set up. I'll let you know how it all works out. I'm sure there will be some things to work out. I like your exhaust set up.
10-20-2011, 12:10 AM | #17 |
Dave
Your order was shipped out on wed thanks for the buss. Justin |
