10-17-2011, 08:14 AM | #1 |
Steering wheel plug question
I purchased a Classic Performance Products steering wheel from LMC. I pulled the old steering wheel out this weekend. I was going to put the new one back in when I noticed the plug at the bottom of the steering column, right before the column goes through the firewall, was different. Should I be concerned? I've posted a picture of the new and the old steering wheel. It seems like I can just plug it into the two prongs on the left side. But, I don't know so I want to ask before I break something.
Old steering column. New steering column. Last edited by 99-LS1-SS; 10-17-2011 at 08:23 AM. |
10-17-2011, 10:10 AM | #2 |
Re: Steering wheel plug question
i think you should be ok. that connection is just for your reverse lights and as long as it is adjusted properly should perform the same function on either column.
10-17-2011, 10:19 AM | #3 |
The first picture is a switch for back up lights only for a straight drive truck and the second picture is a nutural saftey/back up light switch for a auto column.
11-04-2011, 03:43 PM | #4 |
Since I'm converting my Blazer from a 3 speed manual to an automatic, where do I find the plug that would go on the neutral safety switch?
11-04-2011, 09:31 PM | #5 |
Hand Crafted C-10
Try taking the neutral safety switch from your clutch and re-route to the column. Purple wire I think? Don't know if the plugs are the same but it's basically the way you might approach it.
Let me dig around and, if I have one, I'll pop it in the mail. . |
11-04-2011, 10:47 PM | #6 |
its all about the +6 inches
A manual never would have had a neutral safety switch. Personally, I say don't worry about it. Put it in park when you shut it off and there should be no problem.
Posted via Mobile Device |
