Old 10-18-2011, 04:02 PM   #1
Gene
Gene's Avatar
Turning radius question
What am I overlooking here? The truck will make a tighter turn to the left than it will to the right? Im running 91 differentials and power steering.
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
Gene is offline   Reply With Quote
Old 10-18-2011, 07:58 PM   #2
72longbed
72longbed's Avatar
Re: Turning radius question
Gene,
how much did you lift your truck? Usually that limited turning radius has to do with the drag link / steering arm / pitman arm combo. I have had similar problems afer lifting a 72 4 inches. Did you install a 'lifted' steering arm?
Don't worry ... it can be centered and corrected.
Great, Great truck BTW!!
72longbed
72longbed is offline   Reply With Quote
Old 10-18-2011, 08:22 PM   #3
Gene
Gene's Avatar
Originally Posted by 72longbed View Post
Gene,
72longbed
Thanks! Yep I installed a raised steering arm when I lifted the truck. So I need to recenter the drag link?
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
Old 10-18-2011, 08:37 PM   #4
72longbed
72longbed's Avatar
Is your steering wheel centered as you drive down the road? Did you install the steering column and the power steering box?
I'll wait for your answers before I go further.
Thanks.
Old 10-19-2011, 10:31 AM   #5
Gene
Gene's Avatar
Thanks.
Used the power steering gearbox from the 91 suburban 4 wheel drive, I have the tilt steering column from I 71 that's what I'm using, truck drive down the road great steering wheel stays straight, truck does not try to pull to the side the only problem is the truck will not turn very sharp to the right but it'll turn pretty sharp left.
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
Old 10-18-2011, 08:39 PM   #6
snj8198
snj8198's Avatar
Hi Gene
Ya, sounds like you need to loosen the coupler and recenter you drag link assembly. It's easier with the tires off the ground. How's your steering wheel location?
-steve
Steve
1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's
snj8198 is offline   Reply With Quote
Old 10-19-2011, 01:10 PM   #7
snj8198
snj8198's Avatar
That still sounds like a steering geometry issue. It's been so long since I monkeyed with lifts. Is your drag link level?
Steve
Old 10-21-2011, 04:05 AM   #8
mud slut 350
mud slut 350's Avatar
Get a crossover steering setup you will be able to turn sharper both ways and get rid of that factory gm steering crap. with the crossover you wont have as much bumpsteer and when you flex you can STILL turn the wheel. With my stock steering i forgot what front tire was flexed up but the wheel went all the way one way and would not move now witht the crossover it dont matter.
82 k10 350sbc, sm465, np205, dana 60 front 14 bolt ff rear 4 inch susp lift 33's aka "MUD SLUT"
2007 cbr 1000rr
mud slut 350 is offline   Reply With Quote
Old 10-20-2011, 04:15 PM   #9
Mr. 250r
Mr. 250r's Avatar
That has happened on every square body mud truck I've seen the one I just sold, my brothers and my friends but my suburban somehow didn't have it and turned 38s like my 03 turns 35s up until I swapped in the d60 now it has the radius of a semi both ways, I'd go with what snj said and assuming it fixes it the left won't turn as sharp as it did keyword I think.... lol
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854
1988 IROC-Z Camaro - 305/T5 T-Top
1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850
1991 V2500 Suburban Silverado - Sold
1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423
2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold
2003 1500 Silverado
2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold
2005 Silverado 2500HD 6.6/ZF6 CC LWB
Mr. 250r is offline   Reply With Quote
Old 10-20-2011, 05:18 PM   #10
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
Disconnect your draglink at the pitman arm....then turn your steering wheel all the way to to the left till it stops...take a peice of tape and put in on your steering wheel at the 12 oclock position...now turn your wheel all the way to the right and count the number of revoloutions your steering wheel makes...devide that number in half and turn your wheel back to the left that amount. Now loosen the collar on your draglink and either lenghten or shorten it till it reaches your pitman arm again....reconnect it. That will center your steering back up but your more than likely going to have to recenter your steering wheel now.
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 10-20-2011, 06:00 PM   #11
72longbed
72longbed's Avatar
Thumbs up Re: Turning radius question
What Blazerman said .... that's the way.
Don't be surprised if you find that you have to shorten your draglink. I mean actually cut some material from both sides and then screw it back together to center your steering wheel after you follow the procedure that Blazerman outlined.
72
Old 10-22-2011, 05:05 PM   #12
Gene
Gene's Avatar
Thanks blazerman, ill give that a try.
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
Old 10-22-2011, 05:48 PM   #13
Gene
Gene's Avatar
Thanks blazerman, equal turns now. And maybe its all in my head but the steering feels better now?
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
Old 10-22-2011, 08:48 PM   #14
snj8198
snj8198's Avatar
Glad you got it Gene.
Steve
