I want to paint my frame after sandblasting it, but here in Germany we
have only water based products left, because the good ones ( not water based ) are not legal to be sold any longer. The new stuff is by far not as good as the old stuff. This is the point where I need your help. I will on SEMA ![]() or whatever I need to paint my frame as good and durable as possible. The frame shall be black. You could help me very much if you could suggest what to buy and tell me where to get it. I would put my focus more on quality than on the price. I really appreciate your help. Matthias
1955 2nd series 3100 Pickup, MustangII IFS, Ford 9" with 4 link, 4 wheel wilwood disc brakes, 383 Callaway supernatural, 4L60E ![]() 'All people dream, but not equally. Those who dream by night in the dusty recesses of their mind wake in the day to find that it was vanity. But the dreamers of the day are dangerous people, for they may act their dream with open eyes to make it possible.' |
BIG CHEVY 3600 LONGBOX
Re: Which paint / primer for frame
If I couldn't get DuPont Epoxy I would use Por-15, that is if they sell it over there. If not order it from somewhere that sells it.
Here in the "land of the free" so to speak, Eastwood sells it. http://www.eastwood.com/por-15-black...int-quart.html
If I were given 8 hours to chop down a large tree, I would spend the first 6 hours sharpening my ax. Abraham Lincoln http://s729.photobucket.com/albums/w...cpZZ3QQtppZZ20 |
Por-15 will need to be top coated to prevent oxidizing over time. I used Nason Chassis Black, single stage premixed. Do you mean to tell me Mercedes and Porsche are using water based paints? Don't think so. You might need to find a friend at an industrial outfit that could get you some Rustoleum type paint they uses for guard rails, etc. I can see water based for consumer items, but process type plants will still need old school stuff or full time painters.
#4 | |
The stuff I have been buying and using is not waterborne, but I went and looked and they do have waterborne series. Once it cures it must be just as good I guess. I know when water based latex exterior house paints first came out there was big resistance but I got 25 years out of the stuff I put on my house. Keep in mind that the paint manufacturers only have to worry about what it looks like for a short period of time, 98% of all car users only have them for a few years.
#6 | |
![]() Water base is a quality paint. its just the color coat is all that water based. Most small shops just have not switched so many people know nothing about it. I don't mind spraying it. Plus the mfg's do actually car if the paint lasts. Ask Gm when they had to pay to get all the hoods fixed. Last edited by mbgmike; 10-19-2011 at 06:11 PM. |
Originally Posted by OrrieG
I can see water based for consumer items, but process type plants will still need old school stuff or full time painters. True for plants, if you want a durable paint quite a few plants use Carboline brand. Rust o leum is also used but Carboline paint is often used on carbon steel in high oxidizing areas. http://www.carboline.com/ they have been making this kind of stuff for years longer than the auto related businesses. They are the original makers of rust o leum Last edited by mbgmike; 10-19-2011 at 06:23 PM. |
#8 | |
All the german cars you can buy are painted water based. That`s why I cannot get the paint I was using ten years ago. A friend of mine is working in a body/paint shop and told me to get something old fashioned rather than what they use today.
On the two frames I've finished, I used Eastwood's ceramic paint that comes in an aerosol can (can't remember the name) and their primer. It worked very well and sprays really nice out of the can. Tough stuff. On the other frame, I used SPI epoxy primer and then a quart of Rustoleum paint from the hardware store. Equally as tough.
'59 Big Window Fleetside |
#10 | |
#11 | |
1:media blast to SSPC-SP5 (Nace#1) white metal blast 2: 20-30 minute soak of zinc phosphate (metal ready) 3: two full and heavy coats of POR-15 (on rotisserie with proper dry/ tie times) 4: 2 coats of tie coat primer 5: 2 coats of top coat For Matshark POR-15 should be available in Germany, in reality it's just moisture cured epoxy paint which meets the low VOC standard. If you can't find it POR any decent paint store should have a moisture cured epoxy paint, the only difference is brand name. One thing to note if you prep with zinc phosphate don't use a oil based paint it will cause soaponification and delaminate As for waterbase paint it's not much different unless your trying to run a production shop, different tips and cure times but in many ways it performs better. |
find clausen's rust defender
its orange. I think this is it... http://www.clausenautobody.com/prodd...=rust-defender spray it out over bare metal...it will fill all the pits, then you can 180 than and paint or if you want it to be super sweet you can 180 it and re-prime with urethane and base/clear that. some say urethane shrinks too much tho so you could lay over reduced epoxy over it. either way. |
All should really wake up about this paint deal. If not the day is comming you will wish you had good old rustoleum to paint with. I guess all resto guys will need to take a chemistry class soon and make our own paint. Yeah paint is bad but fukushima radiation is healthy right?
