Old 10-19-2011, 11:26 PM   #1
coontz74
6 lug to 5lug or not?
What if a person already has 6 lug drums like on my 69. What is the benefit of swapping to 5 lug if I were going to run 18's or 20's anyway?
I mean, I'm going to swap to disks but I can't find a definite answer as to why I need to go 5 lug?
I klnow this has been covered a ton but I just kind find the reason why somebody would swap other than wheel size, backspacing, etc? Has to be a reason?
Please school me...
coontz74 is offline   Reply With Quote
Old 10-19-2011, 11:59 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: 6 lug to 5lug or not?
Just personal preference.
I like 5 lug wheel "patterns/designs/styles" better.
Most 6-lug aftermarket wheels are designed for the 99-up GM trucks.
The backspacing is usually wrong for our trucks,... plus the center bore of the wheel is too small to bolt on these old trucks.
Most "high dollar" billet wheels can be purchased in a 6-lug pattern.
It's your choice.
Convert the front to 6-lug disc.
Or convert the rearend to 5-lug.
It's all about the wheels YOU decide to use.
Keith
Convert to disc brakes.
Old 10-20-2011, 12:45 AM   #3
coontz74
It's your choice.
Thanks for the response Keith. I've read a lot of your stuff on this forum and value your opinion...
I don't have a problem going to the 5 lug as it seems the price is about the same because I would buy all new spindles and such anyway. I was just curious as to why so many people do it cause I can't be the only one out there with a 69 that hadn't wondered the same thing?
So, when I make the switch to 4 wheel disk 5 lug, what is the bolt pattern? Is it 5 x 5?
Thanks again for the help and bearing with another newbie...
Old 10-20-2011, 01:06 AM   #4
coontz74
Another question Keith,
I'm going with 2.5" spindles and 2" coils in the front and 4" coils with 2" block in the back.
Could you narrow down a few possible senerios I have with backspacing and offset Please?
Old 10-20-2011, 04:48 AM   #5
lolife99
lolife99's Avatar
Unless you are going to run a 20" diameter rim,... I wouldn't use the 2" lowering block in the rear.
ECE sells a 6" drop rear spring.
I would use those to get a 6" rear drop.
Yes, the 5-lug pattern is 5 x 5.
What size wheels did you have in mind?
Nate (72BlckButy) has 20x8.5 (5.5" BS) and 20x10 (4.75" BS) on his 69.
It also has the original 69 rearend housing, which is narrower than the 71-72 rearend housings.
So your rear wheel BS will depend on which ever rearend you use.
(5-lug or 6-lug)
Keith
Old 10-20-2011, 05:56 AM   #6
coontz74
(5-lug or 6-lug)
I thought I would go 18's or 20's hadn't decided for sure yet. I like (ddoles) 71 he has with 20's on it and that's where I got what to run for the stance he has but he was unsure of the backspacing on his wheels?
I have never seen Nate's truck so I'm not sure how it looks? If I keep the original 69 rear end housing how do I convert it to disk without buying new axle ends? Is it just as easy as taking of the drum and bolting on a disc?
If so, I may stay with 6 lug as I'm sure I could find a 18" or 20" wheel 6 lug that I like.
Please bear with me as I'm just learning all this so all I know is the stance I want which looks like a 4/6 drop or something close to that with a 18 or 20 wheel, wide tires and handle good. Other than that I'm at a loss of exactly what I need to do that.
I found the grand slam kit from CPP that looked like what I would go with but I seem to get more confused the more I look at it.
My 69 is also a fleetside if that matters for clearance issues?
I'll try to find Nate's truck and see what it looks like while I await some more knowledge from you...
Thanks for all the info and please be patient with this dummy that's typing...
Old 10-20-2011, 10:04 AM   #7
Tony@AirRideTech
Junior Member
It's your choice.
Do you always have to steal the whole show ?
On the wheels... I completely agree with Lowlife99... You will find a better selection of better looking wheels in 5 lug And being that they ran 5x5 for freaking ever... there are tons of them out there.
Tony@AirRideTech is offline   Reply With Quote
Old 10-20-2011, 03:44 PM   #8
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Haha... he's the king at suspension.
5x5 is a far better option for wheel selection. I would have made the same choice had I not located a wheel that would accomodate the 6x5.5 pattern on a 5-spoke wheel.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 10-20-2011, 05:24 PM   #9
lolife99
lolife99's Avatar
Hey I could always use some help Moderating the Suspension section.
Talk to Ken and maybe you can help me out!
Seriously,... thanks for taking time to check in.
Keith
Old 10-20-2011, 06:37 PM   #10
SCOTI
SCOTI's Avatar
I still check this forum section multiple times daily & help out when/if possible. I'm just not interested in being a hall-monitor or part of a 'club'.
You're not in this alone buddy!
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-20-2011, 06:50 PM   #11
lolife99
lolife99's Avatar
Thanks,... I know you are always helping around here.
I appreciate your wealth of knowledge.
(plus I was just taking a "jab" at Tony. Ha)
Keith
Old 10-21-2011, 12:26 AM   #12
N2TRUX
Happy to be here
N2TRUX's Avatar
And just so you know, all of you guys expertise is appreciated.....even Tony...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 11-04-2011, 08:37 PM   #13
coontz74
It's your choice.
What is the center bore on our trucks? I have found some 18's and 20's with a 78 and 108 diameter? Will these work or will I need to have the bore machined?
Old 11-04-2011, 08:57 PM   #14
coontz74
After researching more, I don't think my bore numbers are accurate?
The wheels I'm looking at are Enkei RT6. Sorry I don't know how to post the link or pic but if you could give them a look and tell me your thoughts?
Old 10-20-2011, 08:33 AM   #15
lolife99
lolife99's Avatar
Look here:
http://67-72chevytrucks.com/vboard/s...d.php?t=353633
No.
You will need to change axles or machine and re-drill your original axles.
Then a disc brake kit will need to be purchased.
I personally am a huge fan of CPP products,... but not their customer service.
Look in the Suspension Marketplace for great suspension deals from the people that support this forum.
These are major suspension companies that choose this board to sell/promote their products,... but they are also members here, just like you and me.
Keith
Old 10-20-2011, 10:36 PM   #16
coontz74
Look here:
No.
I found Nate's truck. It's AWESOME too!! Exactly what I want mine to look like...
If I'm going to have to buy axles I may as well go 5 lug anyway. Looks like it will be comparable in price either 6 lug or 5 lug and at least I would have that huge selection of wheels.
I may just give one of the forum supporters a call and talk with them on exactly what I need to buy? Do you recommend one over the other for a newbie like me with no knowedge?
I will check the Suspension Marketplace right now and see what I can find. Thanks to all for the info, especially you Keith.
SWEET truck Nate!!!
Old 11-04-2011, 10:10 PM   #17
72BlckButy
Tot Roddin'
72BlckButy's Avatar
SWEET truck Nate!!!
Thanks buddy!
Now I can't speak for the 5-lug bore, but I ordered my Vintec's with the following specs:
Billet Specialties Vintec's
Front: 20x8.5" w/ 5.5" BS
- Center Bore: 3.430
- Bolt Pattern: 6 on 5.5"
Rear: 20x10" w/ 4.75" BS
- Center Bore: 4.250 (due to the center hub on the rear axle of my '69 [meas. 3.5"; BS only offered 3.43])
Toyo Proxes S/T ii's
Front: 255/40-20
Rear: 295/40-20
The BS bores were to close for me to order the wrong size so I went with these and ran into zero issues on the mounting.
Let me know if you have any additional questions; more than willing to help you out.
-Nate
Old 11-04-2011, 10:25 PM   #18
SCOTI
SCOTI's Avatar
If there was a 'good citizenship' award for the board, you'd be my 1st nominee .
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-05-2011, 05:24 AM   #19
coontz74
Thanks buddy!
Front: 255/40-20
Rear: 295/40-20
Thanks Nate for the info.. This is exactly what I was needing. Did you or anybody else have time to take a look at those Enkei wheels I mentioned?
Looks like those bore #'s were in millimeters so the 108mm should be the 4.25 that I need. They also offer them with +12 offset and 0 so I should be good there as well correct?
I'm going to save your info so when I go get tires and such I will have a GREAT reference!!!
Thanks again for all the help...
Old 11-05-2011, 05:36 AM   #20
lolife99
lolife99's Avatar
The 20x9's with +12 offset equals a 5.5" BS.
This will work up front.
The rear might require you to run a spacer.
Keith
Old 10-20-2011, 05:17 PM   #21
jimmydean
jimmydean's Avatar
My front is from a '75 C10 and my rear is from a '94 Caprice cop car. Less than $300 for the front and rear, same 5x5 lug pattern and 4 wheel discs. I did it for wheel choice, too.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 11-04-2011, 10:37 PM   #22
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Nah.... you, lolife99 and n2billet. (At least from my perspective).
Thanks Scoti; much appreciated.
-Nate
Old 11-05-2011, 11:44 PM   #23
72BlckButy
Tot Roddin'
72BlckButy's Avatar
And just to add to the confusion....
Think out each upgrade you plan on doing. For instance, do you plan to leave your truck with a static drop? If so, then order the wheels accordind to the static drop. However, if you "might" bag your truck in the future, IMO the BS could/would be different.
Or think about this... lowering the truck lower than 2" up front will require a drop spindle. Drop spindles will result in adding disc brakes. Lowering the truck with a 5-6" drop in the rear will more than likely result in needing new exhaust. New exhaust may cause the need for new headers/mufflers. While you're doing the drop do you want to add a c-notch for added suspension travel? If so... and the list goes on and on.
Think out each move/purchase as it will save you money in the long run.
-Nate
Old 11-06-2011, 05:51 AM   #24
coontz74
It's funny you mention the list goes on and on and on because I was realizing that everyday I chat with you guys...
After thinking on it, just like you mentioned here, I'm going with a 2/4 drop to hopefully eliminate the possibility for all those other things you mentioned?
I want disc brakes and I was set on a 4 wheel conversion but now I'm going with just fronts and rebuild the existing drums for the back. So by that, I'd say a spindle for the front since I'm doing disc's anyway with new stock springs and a 4" spring in back.
Still can't decide on 5 lug or leave it 6 since I'm keeping the drums in the back hence the recent issue of finding a wheel...
I don't know if I need to pick the wheel and tire and work the suspension to fit that or get the stance and HOPE to find a wheel and tire that I would like to fit the stance?? Decisions, decisions, decisions... they are almost as long as the list that keeps going..haha
Thanks for your input and advice. I really appreciate it and hope I didn't wear out my welcome?
Old 11-06-2011, 10:03 AM   #25
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Welll... We weren't going to say anything so since you brought it up... Haha just kidding. That's what this site is all about.
IMO I would setup the suspension prior to purchasing wheels. For instance let's say you order a set of wheels for a 2/4 drop and not a week after purchasing the wheels a board member sells a 4.5/6" drop for half price. Well you just ordered wheels for a 2/4 drop.
Take you time and plan as there is no rush, you just don't want to end up with a truck on stands because you didn't plan for the need for different wheels.
-Nate
