Help with Camaro tach!
Can anyone help me with wiring a Camaro tach into a 84 Custom Deluxe. I have tried 2 or 3, none have registed correctly. I even took one out of a running Camaro that works in the Camaro but won't read correctly in the truck. Any info would greatly be helpful, Thanks
Posted via Mobile Device |
Slots go on anything!
Re: Help with Camaro tach!
Is your truck a 6 cylinder and the tach an 8 cylinder version (or vice versa)? that will cause the reading to be off. If it simply isn't working, it has to be in your wiring. There are only 3 wires, and they should be seperate. Tach signal goes to the terminal on the HEI (or negative on the coil), 12+ goes to switched power, and a ground.
1974 Jimmy- 5.3/4L80e/NP241 |
I mess with alot of third gen camaros, almost everyone I ever had the tach was way off... The 86 z28 I just got the tach read double the actual RPM. But since yours was working fine in the camaro it came out of I dunno. Just something to look for.
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks.. |
im going to be supplying tach conversions for these trucks with repaired gauges that have the board modified to read accurate, but most likely you have the 90-92 tach that blows some resistors and has to have them calibrated and repaired, gauges should be available in febuary-march
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
