10-20-2011, 10:03 PM | #1 |
rusty 66
16 inch rims ?
I was wondering if there was steel 16 inch rims 6 lug I can use for my truck I have 16 inch rims but they are for nylone tires with tubes can I mount radio tires on then
1947 chevy fleetmaster http://www.cbforum.net/forum/ 1966 chevy c10 long bed http://67-72chevytrucks.com/vboard/s...d.php?t=439219 1970 chevy impala custom http://www.layitlow.com/forums/index...pic=349867&hl= |
10-20-2011, 10:30 PM | #2 |
Re: 16 inch rims ?
these are 16's wheel vintique
10-20-2011, 11:01 PM | #3 |
One day...
Re: 16 inch rims ?
3/4 ton 88-98 model trucks are 6 lug just fyi
10-20-2011, 11:51 PM | #4 |
Re: 16 inch rims ?
isn't there an issue with the center hole hub opening on those wheels? Too small or too big or something? I don't know, just asking - seems like I read that somewhere - appreciate anyone's insight on that...
10-21-2011, 01:12 AM | #5 |
60-66 Nut
Re: 16 inch rims ?
Yes that is correct. Those '88-'98 6 lug wheels have a 3.06" diameter center register hole. These older trucks have hubs and axle registers that measure aprox 3.5" diameter. Those newer wheels also have a deep backspacing.
10-21-2011, 07:38 AM | #6 |
Check The Champ, Demonstrator
Re: 16 inch rims ?
This is an original 16" wheel for our series.
I widened mine to 9 1/2". Stock steel 16" off 70's truck on the front. 17.5" converted to 17" on the rear.
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
10-21-2011, 11:39 AM | #7 |
rusty 66
Re: 16 inch rims ?
here is the rims i am using they have tubes do you guy think i can use radio tires with out tubes on these rims
the first rim has a 5.50/16 and the second rim a 6.00/16 is what am know using but i would like to get radios tires i been driving this truck even day and don't want to ruin this tires
1947 chevy fleetmaster http://www.cbforum.net/forum/ 1966 chevy c10 long bed http://67-72chevytrucks.com/vboard/s...d.php?t=439219 1970 chevy impala custom http://www.layitlow.com/forums/index...pic=349867&hl= Last edited by juanz1947; 10-21-2011 at 11:45 AM. |
10-21-2011, 12:07 PM | #8 |
Re: 16 inch rims ?
Juan, can you snap me a pic of your fender emblem?
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
10-21-2011, 03:01 PM | #9 |
Re: 16 inch rims ?
Well I talked to a guy whose been around wheels and tires all his life. The only issue you might come across is air leakage through the rivets that hold the center section to the ring. You might paint the inside of the wheel rivets to seal them. The Air Valve will have to have the larger diameter base so it will seal in the valve opening. Your wheels are the same as the white wheel picture above.
10-22-2011, 03:17 PM | #10 |
rusty 66
Re: 16 inch rims ?
It has custom camper on emblem
10-22-2011, 06:36 PM | #11 |
Re: 16 inch rims ?
I thought they stopped making the wheels with the clips on the inside back in the 50's and went to the wheels with the outside "nubs" to hold the hubcap on? I could (probably) be wrong. But back to the original question, I used a set of those wheels on a 64 i had years ago and with radial tires and never had any problem with them leaking at all. Drove the truck like that for about 10 years.
08-14-2017, 06:25 PM | #12 |
Re: 16 inch rims ?
Zombie thread alert
I had a 65 burb that came with 16in clip rims that looked to be original. I noticed that my new 66 K10 burb the 16in rim was an option. Were the clip rims (same as the ones shown above) correct for a 66 k10? thanks |
08-15-2017, 02:25 AM | #13 |
Re: 16 inch rims ?
Juan, I'd like to have your old rims and tires when you switch over, if you want to get rid of them.
I have a '66 Custom Camper too. |
