Old 10-21-2011, 07:57 AM   #1
fryer1979
Redneck Hillbilly
fryer1979's Avatar
Question for you I-6 fellows.....
I've got some friends really pushing me to build my (or another) I-6 for my truck instead of going V8. I'm starting to warm up to the idea, as I have always enjoyed driving the inline engines. I have a couple quick questions regarding the headers for these engines. Are there any clearance issues with the mechanical Z-bar shift linkages? And.....For lowered trucks, do the long tubes for the I-6 hang low like the V8 headers do? What headers would you guys more recommend for a dropped and manual trans pickup? Thanks.
fryer1979 is offline   Reply With Quote
Old 10-21-2011, 09:46 AM   #2
gtbrain
Re: Question for you I-6 fellows.....
I used the cast iron headers from Tom Langdon at Stovebolt. Excellent fit for my application.
http://stoveboltengineco.com/index.p...=0&sort=normal
gtbrain is offline   Reply With Quote
Old 10-21-2011, 11:16 AM   #3
vin63
It's Better With Nitro
vin63's Avatar
X2...If you are going to lower your truck, I would go with Langdon's or a set of shorty headers. Here's a photo of Langon's on a 292 conversion we did on a friend's Chevy II:
Here's a set of Clifford shorty headers:
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 10-21-2011, 01:07 PM   #4
DLOE65
DLOE65's Avatar
Definitely use langdon's Cast or Clifford shorties. Best 2 on the market. Both are awesome guys, you can call up and talk to them directly.
DLOE65 is offline   Reply With Quote
Old 10-22-2011, 05:06 AM   #5
Vernski
Tom Langdon's cast iron are the best if you don't like hearing the hearing the headers "tic" The long tube headers are no good for that reason,and they will drag on the ground if you want to lower your truck. You may have to move the clutch linkage to the right a little, but the three on the tree should be fine. Cast Iron is best IMO...Vernski
Vernski is offline   Reply With Quote
Old 10-22-2011, 05:29 AM   #6
fryer1979
Redneck Hillbilly
fryer1979's Avatar
Vernski: I'm running a 4 -speed granny on the floor, same issue with the clutch linkage there?
Old 10-22-2011, 06:30 AM   #7
Vernski
I don't know if mine was an exception or not it's a 65 GMC w/230 w/gr 4sp I had to cut the arm that goes to the clutch and move it an inch or right so it would clear the front head pipe as it comes down beside the bottom of the block. I had pre-bent pipe from a kit that I welded together, possibly a muffler shop could bend the pipe to clear it. So that's what happened in my case and you may not have to do that if you have access to a pipe bender. The front header comes down at an angle inline with the clutch...Vernski
Old 10-22-2011, 07:28 AM   #8
fryer1979
Redneck Hillbilly
fryer1979's Avatar
I see, that makes sense. Hey, where did you find an exhaust kit? I'm not having much luck searching yet (only really been seriously thinking on this for a few days now), and there is only one exhaust shop in town. The guy is a bit of a jerk-off who thinks his work is worth gold, so it would be nice just to find something with a bunch of prebent pipes even. I can weld something together and add my own mufflers if necessary, I just don't have a way to bent the pipe so some kind of kit would be great. Thanks again.
