10-21-2011, 04:34 PM | #1 |
Cracked Frame ( Brackets and Reinforcements Needed )
What would you do? Just weld something ON TOP? |
10-21-2011, 04:45 PM | #2 |
Re: Cracked Frame ( Brackets and Reinforcements Needed )
that weld is crap, clean it all of and put a good backing plate. on it.
or a new truck. |
10-21-2011, 04:50 PM | #3 |
10-21-2011, 05:13 PM | #4 |
I seen one cracked right there and it was from a bad front end colision. Maybe the frame was straightened and wasnt repaired correctly? I would be looking for a frame personally.
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks.. |
10-21-2011, 05:14 PM | #5 | |
Its just going to be a truck to take to dinner and stuff like that no hardcore offroading... If I went with a new Frame where would I get one and how much? |
10-21-2011, 05:17 PM | #6 |
here is the one I saw and it was from a front end wreck
10-21-2011, 05:18 PM | #7 |
ok ok they fix it?
10-21-2011, 05:19 PM | #8 |
no the guy that bought it put a new frame under it.
10-21-2011, 05:23 PM | #9 |
how many hours would swapping a frame be?
How much for a frame? |
10-21-2011, 06:08 PM | #10 |
are you a good welder? do you have a nice 220V machine? Easiest thing to do is take it to a frame shop, have them check to see if the frame is twisted, bent or diamonded in anyway... if it is they straiten it, and ya weld the crack up solidly. Those few booger welds sitting on top the metal is not a solid weld in any shape or form.
10-21-2011, 06:12 PM | #11 | |
10-21-2011, 06:22 PM | #12 |
10-21-2011, 06:23 PM | #13 |
You can drill a hole at the end of the crack to stop the crack... then weld the hell out of it with a plate!
1991 Mustang GT Vert, T-5 w/ Pro 5.0, Trick Flow upper & lower, BBK cold air intake, 3:73, BAMA chip, etc. 1988 K5 Blazer, [coming soon] TBI 400, SM465/NP208, 12 bolt rear, 3:08's, looks like a 1980. 1998 Jeep Grand Cherokee 4.0 fully loaded daily driver! Where there's a will, there's a rig! |
10-23-2011, 01:06 AM | #14 | |
I can still count my vehicles on two... wait three hands. |
10-23-2011, 01:28 AM | #15 |
Thats repairable. Dont frame swap for that. Easy to straighten, then weld fishplate on. There are a whole lot of 50's trucks out there with camaro clips welded on. Speaking of fish hows the mullet festival this year? Damn i miss that gulf coast cookin.
Posted via Mobile Device |
10-24-2011, 08:34 AM | #16 | |
10-24-2011, 12:38 PM | #17 |
Hit up 67_SS396, he has a CUCV blazer that has had a hard crawling life. The crack in your fram looks Identicial to what Buster has been through !
10-21-2011, 06:46 PM | #18 |
Another Day, Another Dollar
why is either side of the crack flared up like that?
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box "its hip to be square" |
10-21-2011, 07:18 PM | #19 |
My guess is the frame rail was knocked way over from a wreck. and someone pulled it back straight.
10-21-2011, 07:17 PM | #20 |
I'd grind all that old garbage booger weld off of there and beat that frame back into shape there and weld it up nice. Does the truck drive straight? look like everything's in decent alignment?
10-21-2011, 07:27 PM | #21 |
take a monkey wrench to it cut a gash into it that goes straight through and is about 1/8 of an inch clamp backing plate and do a good long slow weld
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ] 1999 k3500 crew cab dually 6.5tdi/4l80e |
11-11-2011, 06:38 PM | #22 |
Good work. Looks much better and is no doubt safer now.
Steve Member of the Foot Pedal Club '83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL, Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws, 350 HP 350 crate engine from Jegs, Turbo 400 |
11-11-2011, 06:40 PM | #23 |
