Old 10-21-2011, 07:56 PM   #1
Daytona#3895
Daytona#3895's Avatar
Stall after a sudden stop
My truck is an 87 with a 350 tbi. Coming home from work the other night, a deer jumped right out in front of me. I locked up the brakes and the trucked stalled. I have had a bunch of older carburetor cars do this because of the float bouncing around, but never a fuel injected one. The next day I sprayed for vacuum leaks around the base of the throttle body and at all of the ports. None found. I scanned for codes. None found. It also wants to stall on a cold start as well if I immediately put in gear. Any thoughts?
Current vehicles
1987 Chevy V-10
2006 Dodge Charger R/T Daytona
2004 Jeep Wrangler Sport
1996 Jeep Cherokee Classic
1968 Chevy Camaro SS
Daytona#3895 is offline   Reply With Quote
Old 10-21-2011, 08:41 PM   #2
cjlinkster
cjlinkster's Avatar
Re: Stall after a sudden stop
Wow, glad that you were able to stop it in time.
The only two things that come to mind. When was the last time that the fuel filter was changed? Could be some crap in the filter.
The other possible thing, perhaps you experienced a vacuum leak from the brake diapragm.
1984 C20, 454, 4 speed named "Gold Member"
cjlinkster is offline   Reply With Quote
Old 10-21-2011, 09:27 PM   #3
875.3CHEVY
torque conver clutch if you have overdrive or a 350c trans can cause that.thats all i can thinks of
875.3CHEVY is offline   Reply With Quote
Old 10-21-2011, 09:33 PM   #4
Daytona#3895
Should have stated that its a turbo 400. It fired right up like nothing even happened after it stalled out. I also had a half a tank of gas so I don't believe that the fuel sloshed in the tank. Was only going about 25-30 mph as well. Possibly something electrical cut out causing the stall?
Current vehicles
1987 Chevy V-10
Old 10-22-2011, 03:12 PM   #5
Rogue_Alphonse
Rogue_Alphonse's Avatar
Sounds like the TPS. I've had it happen twice, with the same symptoms.
1991 Mustang GT Vert, T-5 w/ Pro 5.0, Trick Flow upper & lower, BBK cold air intake, 3:73, BAMA chip, etc.
1988 K5 Blazer, [coming soon] TBI 400, SM465/NP208, 12 bolt rear, 3:08's, looks like a 1980.
1998 Jeep Grand Cherokee 4.0 fully loaded daily driver!
Where there's a will, there's a rig!
Rogue_Alphonse is offline   Reply With Quote
Old 10-22-2011, 06:16 PM   #6
Heavy87Chevy
Heavy87Chevy's Avatar
This has happened to me a few times lately, also an 87 with f.i. & 700R tranny
Heavy87Chevy is offline   Reply With Quote
Old 10-23-2011, 01:03 AM   #7
slick78
I dont mean to jack ur thread but my truck does the same thing. Mines a 78 with a 4.1 straight 6. I stoped at a red light real quick and my truck started to studder then it died.
slick78 is offline   Reply With Quote
Old 10-26-2011, 01:44 PM   #8
sag4spd
Did any of you guys have your cluster out recently? The speed sensor is attached to the back of the speedometer. Green box with small optical eye at the end of a wire. The eye plugs into the back of the speedo. My truck did the same thing for years--Very annoying when you are plowing snow.
This only pertains to fuel inj. trucks.
sag4spd is offline   Reply With Quote
