Old 10-22-2011, 12:07 AM   #1
rick0312
rick0312's Avatar
remove that old bed!! 42yo carriage bolt
If you are contemplating whether or not to remove that old steel bed here is one of the 8 carriage bolts that i removed. I think if I would have accelerated to fast the whole bed would have broke free and been left behind! Glad i decided to remove the Bed!
69 C10 LWB GM 350 crate motor, 3.73 rearend
rick0312 is offline   Reply With Quote
Old 10-22-2011, 12:10 AM   #2
Hubscrub
Cruzin
Hubscrub's Avatar
Re: remove that old bed!! 42yo carriage bolt
i removed mine but not that bad (i'm in the south though) glad you found that have you checked your u-bolts
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 10-22-2011, 12:15 AM   #3
rick0312
rick0312's Avatar
u bolts and trailing arms all new........thanks
Old 10-22-2011, 11:07 AM   #4
Andy4639
Old member
Andy4639's Avatar
Cool Re: remove that old bed!! 42yo carriage bolt
Yea I guess it was time for them to be replaced for sure!
I did mine several years ago when I first had the truck painted. 1990 I think are maybe 91,92. It's been way to long ago now.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 10-22-2011, 12:01 PM   #5
no moa
no moa's Avatar
wow!
I picked up my truck, headed down the road with it on the trailer, and i look back and the bed it 2ft out on the pass side, i was like oh ****. The only bolt holding my bed on had snapped off it wasn't that bad, but close, and there was NONE in the other holes. I was lucky it didn't slide off.
1972 C10 Deluxe.Shortbed. 402/400. A/C, white interior, needs complete restore. Project Red, white and blue. Used to be a Longbed apperently.
http://67-72chevytrucks.com/vboard/s...d.php?t=451950
1971 c10 step 250 3 OTT
1969 c30 TOW-MATER. 307 4 speed, holmes 440 body.
http://67-72chevytrucks.com/vboard/s...d.php?t=451082
2006 CTS-V LS2 6spd.
no moa is offline   Reply With Quote
Old 10-22-2011, 12:28 PM   #6
BMERDOC
BMERDOC's Avatar
Mine has (had) a wooden bed. Because all the wood had rotted and was missing you shake the bed up and down a lot. It made for a very noisey ride. I burned off the bolts and added two 18" strips of 3/4" plywood followed by 8 new carriage bolts. Tightening the bed and adding a real exhaust made so much improvement it seemed like a different truck!
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 10-22-2011, 02:05 PM   #7
70c10-08
70c10-08's Avatar
I dont have any pics of em but all my bolts were like that on my 70 bed bolts cab bolts radiator/ grill support bolts ya they deffinatly needed to be changed
70c10-08 is offline   Reply With Quote
