Old 10-22-2011, 04:17 PM   #1
williamsboys
williamsboys's Avatar
Question tierod question (working on it now)
just got the disc brake kit for my 66 off of brothers and im to the point where i need to put the new tie rod ends on. It came with the center piece also but on the old one the center piece is tightened on the tie rod ends where as the new ones are loose and don't really tighten. Should i just use the new ends and put them in the old center pieces?[IMG][/IMG]
williamsboys is offline   Reply With Quote
Old 10-22-2011, 06:06 PM   #2
concretekiller
Re: tierod question (working on it now)
if i had to guess i would say to just use the new pieces you recieved. with the new ones, one has right hand thread, and the other has left hand thread, that way when you get an alignemt, all that has to be adjusted is that center piece. turn it one way, and they will shorten. turn it the other, and they will lengthen. it doesnt appear that there would be a chance of them shortening or lengthening on there own through vibration or anything like that.
concretekiller is offline   Reply With Quote
Old 10-22-2011, 06:10 PM   #3
markeb01
Senior Enthusiast
markeb01's Avatar
The original connector tightened with clamps over the split ends of the sleeve. The new connector should be tightened with jamb nuts on each end of the sleeve which are missing in the photo. The ends of the new connector aren't split like the original so clamps won't work on this design.
Old 10-22-2011, 07:11 PM   #4
williamsboys
it came with no jamb nuts. i put it all together and just did like concretekiller said so i reckon thats it. also any info on the way the new brake lines are suppose to be ran?. no instruction came with lines and power mastercylinder. Thanks
Old 10-22-2011, 07:42 PM   #5
T2vigil
T2vigil's Avatar
I'm with Mark. Even if it was not supplied with Jam nuts I would find some to use.
T2vigil is offline   Reply With Quote
Old 10-22-2011, 08:08 PM   #6
concretekiller
this is true.
Old 10-22-2011, 11:31 PM   #7
Captainfab
60-66 Nut
You definitely need jamb nuts with that style of adjusting sleeve. If you don't, vibration will move it, and you will be out of alignment.
Old 10-23-2011, 08:51 AM   #8
williamsboys
alright thanks guys.
