Need wheel help
i need help choosing the correct backspacing for the rims i want as much negative backspacing as possible without causing any serious issues
also need help with choosing the correct bolt pattern |
Re: Need wheel help
On the rear a 5.5in backspace on a 10in wide rim puts the wheel almost dead center. Not sure about the front but I've read that 20x8 with 5.25in backspace is perfect.
John 82 Chevy Silverado 350ci/TH350 ![]() |
Re: Need wheel help
could you teach me about backspacing what it means and what it does because i have no idea what it is talking about
Re: Need wheel help
Back space is the distance from the mounting surface of the rim to the outetmost lip of the backside of the rim. Does that make sence?
Re: Need wheel help
yea kind of the more backspacing the deeper the rim?
Re: Need wheel help
Not exactly. Example; A 10in wide rim with 5.5in of backspace has 5.5in of rim on the backside and 4.5in of rim on the frontside.
Re: Need wheel help
okay from what i see in the diagram the smaller the backspacing the deeper the rim and a negative backspacing is a deeper rim? right?
Re: Need wheel help
Here's a Backspacing diagram. the face of the wheel is to the LEFT.
![]() Here's a Wheel Offset Diagram. the face of the wheel is to the RIGHT. ![]() |
Re: Need wheel help
I'm guessing your truck is 77c10 right? What wheel and tire set up do you want and is it lowered or not?
Re: Need wheel help
i dont know what the backspacing is on my rims i will go out and check that and no its not lowered but i am going to lower the rear end 2 inches and leave the front stock height just to get it level i currently have 15s but i want to change to 18s
Re: Need wheel help
okay the backspacing on my current rims is 3 1/2 inches and front spacing is 6 inches they are 15s sitting on 31x10.50r15lt standard rim 81/2j what ever all that means
Re: Need wheel help
my truck
the rims i want backspacing and all that isnt correct yet just the rim style http://www.summitracing.com/parts/MBW-61325/ |
Re: Need wheel help
i never thought those rims were 10in wow thats awesome thats alot of rim under that tire haha
Re: Need wheel help
From what I've been hearing 18s are getting hard to find wide enough tires for, but I could be wrong.
#15 |
Re: Need wheel help
You have 15x10s with 3.5in backspace.
