10-24-2011, 09:08 PM | #1 |
Power steering help
I changed out a growling powersteering box on my 1972 C-10 i went with a 1977 used box that seemed in good shape, at the same time i instaled a new pump from NAPA and fit it in to my Reservoir. Now the steering is a little to free. What i mean is its a little to easy to turn? I have a Finished 1971 Short wide. That has perfect feeling steering but it came that way when i bought it. What should i change to get the steering more firm. The box i installed is Quiet and tite and so is the pump. Thanks for any help you can give.
10-25-2011, 11:32 AM | #2 |
Re: Power steering help
Can you explain what exactly you mean an why is it a problem? I'm confused lol.
1969 Chevy c20(Miss Hackjob) |
10-25-2011, 11:46 AM | #3 | ||
"I ain't nobody, dork."
Maybe the later model box has a quicker ratio?
Is that what you're askin'? Gary
10-25-2011, 12:00 PM | #4 |
You mean you can steer with 1 finger now?
1967custom |
10-25-2011, 01:23 PM | #5 |
Active Member
These types of steering gearboxes usually feel that way. Maybe your old one was too tight and your other truck has all tighter front end components.
I would start by making sure the gearbox is adjusted properly and that tierod ends, drag link, pitman arm and ball joints are in good shape. |
10-25-2011, 07:55 PM | #6 |
All of the Steering stuff is new. The truck steers Great its just that the power steering is to easy. Yes 1 finger easy. My other truck has a much firmer steering and I like it a lot better. It is the Quick ratio box now. But my other truck has that also. Any body ever try a Steering control valve? I bought one from Brothers. Its made by Heidts Rod shop and looks like it could work. but i was thinking it might be easier to change to a diffrent pump?
10-25-2011, 08:16 PM | #7 |
Here is a picture of the 71 i rebuilt in 2009. Can you tell what Steering box and pump it has?
