Old 10-26-2011, 11:14 PM   #1
bobber80
Air ride shock help
Hay guys Im needing shocks for my 62 swb it has a full air ride suspension with a four link in the rear it almost lays frame.. what is the propper way to measure for shocks do i measure at full extension of the bags or just at ride height.....
THANKS for any help you can send my way
bobber80 is offline   Reply With Quote
Old 10-26-2011, 11:35 PM   #2
vin63
It's Better With Nitro
vin63's Avatar
Re: Air ride shock help
I always take my measurements at the ride height and take into account how much suspension travel I want. Then I use a shock with that height as the middle of the shock travel that does not bottom or top out before my projected suspension travel.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 10-26-2011, 11:37 PM   #3
SCOTI
SCOTI's Avatar
You need to know the dimensions between the shock mounts @ full compression, full extension, & @ ride height. You want to try & find a shock that comes as close as possible to your specific dimensions & works best for you (no universal 1 size fits all p/n).
Full air suspension including custom shock mounts or??
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-26-2011, 11:41 PM   #4
bobber80
I have stock mounts in frount and custom mounts in back
Old 10-26-2011, 11:55 PM   #5
SCOTI
SCOTI's Avatar
Use different upper mounts for the fronts. They'll allow a longer shock to be used which gives better ride quality (greater extension & compression before bottoming out) & should increase your shock options.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
