Old 10-29-2011, 09:44 PM   #1
iceship
Just alittle lift
87 c10. 2.5 spindels and 2in drop coils...... I'm just a bit to low for the rims I got ... Big boy 24, but was jut looking for 22... So I need to go up 1in or 1.5in.... Has anyone used the twist in spacers from autozone or advance.... How many did u use to get the clearance you need...
To LOW
To HIGH
iceship is offline   Reply With Quote
Old 10-30-2011, 03:24 AM   #2
SCOTI
SCOTI's Avatar
Re: Just alittle lift
Energy Suspension made a urethane coil spacer that was 1" @ one point in time. Check them out & see if it's still avail before using those 'twist-in' style spacers for the coils.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-30-2011, 08:45 PM   #3
iceship
So I put a set of coil booster on they are just a tad less than 1.5in..... so it is lower then stock just a bit... it my settle some more... it not ill cut .5in off....
Old 10-31-2011, 01:22 PM   #4
tubbedII
needs more $$$
tubbedII's Avatar
Which type of coil booster did you use? The knuckles or the black rubberish spacer? If you got the rubber type, don't cut a coil because it'll eventually break down and your ride height will go back to what it was, and if you cut it'll be even lower.
I think Belltech makes a poly one too that goes on top of the spring rather than inbetween. I have one on my s10 to level it out, but don't see why you couldn't put 1 on each side.
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 10-31-2011, 08:49 PM   #5
iceship
I got the rubber one you put on the bottom but u can put them in between..... the drivers side is just right, other side is a inch high...
Ill keep my eye out for the other ones...
