10-30-2011, 01:51 PM | #1 |
WHEEL COVERS won't go on - any tricks ?
Does anyone know any "tricks" to get a stock full wheel cover on a stock wheel ? I've been using a rubber mallet and I can get most of it on - but not the final SMACK - it's too tight !!! THANKS !!! |
10-30-2011, 07:45 PM | #2 |
Re: WHEEL COVERS won't go on - any tricks ?
Steve,
sometimes he tabs on the inside (what actually holds the wheel cover on the wheel) bend outward and actually prevent the cover from going on all the way. Not corrected, the wheel cover will far off while driving down the road. To correct, just remove the cover and bend the tab(s) inward and install again. It may take several trys to get the tab(s) just right. |
10-31-2011, 03:14 AM | #3 | |
10-30-2011, 09:57 PM | #4 |
Grandpa in the rustmobile...
our chevy belair i bent the tabs further out so they would stay on the wheels so maybe need to bend them so there not so tight?
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
10-31-2011, 02:32 PM | #5 |
VA72C10
Hit it harder???
Looking for a 67-72 swb or blazer project in or around VA. |
11-05-2011, 04:53 PM | #6 |
Still haven't got them to stay on. Below, is a picture of the back of the wheel cover. Those long tabs don't bend much. There isn't too much paint on the wheel either, by now it's scratched down to the bare metal. Any other suggestions on how I can get these things on ?!!! . . . . |
11-05-2011, 05:45 PM | #7 |
Are you sure those are "stock" wheel covers? Are they the backside of highlander covers? They don't look like regular c-10 wheel covers to me.
72 Cheyenne Super 80 Silverado Blazer 2wd |
11-05-2011, 05:51 PM | #8 |
Yes, they are Highlander wheel covers but they should fit on the same 15 inch steel wheels that could have has the PO1's on them.
. . . . Life is short . . . we only have, right now. . . . . My 70 C-10's BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=475526 |
11-05-2011, 06:01 PM | #9 |
Yes they should fit, but when the people above were talking about the bent tabs, I don't think they had in mind highlander covers. I don't know any tricks for those style covers......Good luck.
11-06-2011, 05:58 AM | #10 |
My father insisted on having a set of Caprice wheelcovers on his G van and they were tight. I'd have to start them at the valve stem (at 6 o clock) but only enough to hook not seat. Then sitting on the ground with two feet holding the cover bottom edge at 5 and 7 o'clock, start wacking it in at the top at 12 then 11 and 1 while holding a lot of foot pressure. They would work into place but it usually took going around the cover twice or thrice to fully seat them. Never lost any though.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
11-06-2011, 06:05 AM | #11 | |
11-06-2011, 08:14 AM | #12 |
wheel design changed starting 1971 to clear disc brakes/ so it might b possible that there is a problen with full hubcaps not fitting properly on some wheels
i dont know for sure as i've never been much of a hubcap guy tho
11-06-2011, 08:40 AM | #13 |
laying low
A rubber mallet may be of help in making them seat. Alignment and tire shops used to use them regularly back when cars had hubcaps.
11-06-2011, 09:17 AM | #14 | |
. . . and I HAVE been using a rubber hammer !!! Below, are some pictures of the wheel - maybe someone will know what year it is for ( or what year it ISN'T !!! ) THANKS !!! . . . . |
11-06-2011, 10:02 AM | #15 |
Possible clearance issue on hub or wheel weight?
1967 GMC 3/4 ton Fleetside 350 ci Chevy I'd rather do it myself and spend the extra 500 dollars |
11-07-2011, 05:01 AM | #16 |
put some heat behind that swing brotha..
think your just being a tad to carefull |
11-07-2011, 05:21 AM | #17 |
11-07-2011, 06:57 AM | #18 |
are the covers for 16" wheels
11-07-2011, 10:57 AM | #19 |
I just got off of the phone with the guy who did the restoration ( and supplied the 5 lug wheels ) He said they were off of a 72 pickup that he used to have - SO, these Highlander wheel covers SHOULD go right on !!!
11-07-2011, 01:27 PM | #20 |
maybe the trucks telling you something
11-07-2011, 01:38 PM | #21 |
I'm sure it's trying to tell me to put some "cool wheels" on it.
I just bought these tires and don't have the money now to change it all over - it's just going to have to wait !!! Below, is a picture of what it had from the factory - I thought the Highlander wheel covers would be an IMPROVEMENT !!! . . . . |
11-07-2011, 07:50 PM | #22 |
The Niner
When I originally got my C/20, I got some (what I thought were) new replacement rims from Autogeek.com. Turns out they were cheap chinese knockoffs and the nubs for the hubcaps didn't quite lineup and the caps never fit. They weren't off by much, I was able to get 3/4 of the cap on, but it wouldn't go all the way. I got some used F*rd rims and they popped right on.
BTW, I think the dogdish hubcaps look better than the full ones, but that's just me...
"A good racer is one whose head is in communication with his balls." - Richie Evans 1970 C/20 - 402/TH400/3.54s - 74K miles 2003 GMC Sierra 2500 - Wheatland Yellow Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183 Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/ |
Tags |
hub cap, installing wheel cover, wheel cover |
