Help needed on AM/FM
I replaced the orig. AM radio in the 68 with a factory AM/FM I had, would light up but not play, ok thinkks I radio bad, fast forward to today. I installed a known working AM/FM unrestored - no lightes sound etc. , then I replace this one with a restored version from Radio rescue (yes three factory am/fm's) and same thing. I realize that there is an issue just dont know what it may be. Fuse is intact but no power showing up at radio. Any suggestions before I tear into this.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
Re: Help needed on AM/FM
Mine lit up but no sound, It was a speaker wire grounding out.
I'm not as good as I once was, But I'm as good once as I ever was. |
Active Member
![]() Join Date: Jul 2007
Double check your connections. Make sure the wires are not broken as mentioned above and insure you have a good speaker and antenna connection. The antenna, if it's an aftermarket, sometimes won't make good contact.
