Alright Alright Alright
GMC Paul's weather stripping
I am currently trying to find a set of the GMC Paul's press on weather stripping I keep hearing good thins about. On the web site I only see one thing that says:
67-72 Door Opening Weather Strip #139684. I dont know if that is the glue on or press on type. Does anyone have a part number for the press on type?
1972 Cheyenne Chevrolet red and white 357ci, Vortec heads, GM Performance high rise intake, Comp 268H .454/.454 218/218 110 LSA Quadrajet carb, Flowtech headers, 2.25 40 series HEI, Curve kit, TH 350, 3.07 gears 275/60/15s on 15x8 rallies |
Man of Mini-Talents
Re: GMC Paul's weather stripping
2660241 1967-72 Door door opening weatherstrip attaches to cab and seals door to cab, sold in pairs. A Glue Less, Push-on Alternative to factory 67-72 door seals. These push on, and will conform to the stock 45 degree mitered corner above the vent window assembly. And the more bulbous seal, seals tighter than 67-72 factory replacement seals , the exposed part of the seal on the inside the cab is much cleaner looking also. For Pickup doors only. LIFETIME WARRANTY To Original Purchaser Manufactured By Precision.
This is right below the item number you saw on the web site.
Steve Project - Ruth 66 Skylark Project - Lola 60 Biscayne Project - Iron Ox 54 GMC 100 Project - Darth 69 Camaro |
The item right below is the 67-72 Suburban Door Opening Weather Strip #132065
http://www.gmcpauls.com/door_parts2.htm I cant seem to find it.
Man of Mini-Talents
Active Member
![]() Join Date: Jul 2007
2660241 is the correct pn. I got this a few years ago and seals good. The only thing you may have to do is to adjust the door striker plate slightly because it's going to be a tight fit and probably be hard to shut the door. I moved mine just enough so that it didn't take as much effort to close but still sealed tight.
What I found out is that because of the tighter seal, there's actually pressure created when you close the door fast so I usually close it until there's about 8 inches and then push it a little harder from there. |
Thanks guys.
Are these made by GMC Paul? I'll be needing seals by spring.
I think mine were made by Precision but I bought them from GMC Pauls ,great service too .Actually I have gotten great service on everything Ive ordered from them and prices are good too.
