11-01-2011, 07:36 AM | #1 |
67 c20 drop spindle
Anyone know where to find a good set of drop spindle for a 3/4 67. I found a couple set but there all 1/2 ton conversion and i want to keep my 8 lugs wheels. Does 1/2 ton drop spring work well on a 3/4. Tanks in advance. By the way i'm new to this forum and i find it awesome!
Posted via Mobile Device |
11-01-2011, 10:57 AM | #2 |
Junior Member
Re: 67 c20 drop spindle
The 1/2 spring will go right in there because it is essentially the same exact front suspension with exception to the ball joints and spindles. If you not planning on using it as a 3/4 ton I would ditch it and go with 1/2 stuff anyway. better wheel selection and more compliant ride quality.
11-01-2011, 12:44 PM | #3 |
thank for the info tony , i will go with the 1/2 spring set then but i really want to keep it 8 lugs cause i'm on a tight budget and i already have the wheel and tire and i dont want 6 lug upfront and 8 in the rear that's why i like to find 3/4 drop spindle if that does exist?
11-01-2011, 01:49 PM | #4 |
Junior Member
not that I am aware of.... but if you are going to convert... convert it to 5 lug
11-01-2011, 05:31 PM | #5 |
Yeah you're right!
