Carb Help
Rochester mono jet carb, on a 250, I unplug my auto choke during the summer cuz i dont need it, but now its getting cold so i plugged it back in....but the idle is really high, and i think its the vacuum, cuz, the spring on the vacuum, compresses all the way, and i even unpluged the vacuum hose, and the truck will go back to its normal idle...any ideas?
Re: Carb Help
not to experienced with auto chokes but could you put a stiffer spring in?
Adam My 1967 C10 - Turbo 250 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=485843 (608) 214-8706 |
Active Member
![]() Join Date: Jul 2007
Re: Carb Help
What model carb you got?
Who's got steelies?
![]() Join Date: Feb 2006
Re: Carb Help
I don't understand what you mean by unplugging the auto choke. Like unplug the vacuum line to the choke pull-off?
![]() ![]() ![]() ![]() ![]() ![]() How to add a trip odometer to your 67-72 stock speedometer How to rebuild your Q-Jet My Truck Page My Youtube Channel |
Re: Carb Help
By unplugging the choke i mean, there is a wire that runs from my ignition, all the way to the choke and plugs into this thing i dont know what it is on the carb.
Re: Carb Help
Does the thing you unpluged look like one of these?. From my 70' 292
#7 | |
Active Member
Re: Carb Help
You say a wire goes to the choke and plugs into "this thing". I'm confused... |
I am a Referee of life.
Re: Carb Help
Sounds like you plugged an Idle solenoid in.If it looks like the above and the pin from the solenoid extends and makes the linkage increase the idle,then that is what it is.Usually used on AC to keep the engine from stalling when the AC is putting more load on the engine.The choke is a Flapper(butterfly) in the top of the carb.It is usually operated by a cable or thermostatically(Bi-metal) spring.There may be a idle solenoid or a vacuum line to help open/close it but we'll need more pics to tell.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
Re: Carb Help
Ok I'll get some pics up soon.
Posted via Mobile Device |
