Please if you know help, Is there a way to put disc brakes on this truck besides a conversion. Will 71 or a 72 work? Do I have to change the whole front end or just ball joints and spindels. thank ytou very much any info is greatly appreicated. rdbman
Re: 1968 Chevrolet C-10
i belive you can use the 72 disc setup ,but you need the spindles and ball jounts for the 72 also
1971 - 1987 will work IIRC. I think you will want A-arms and out. You can actually unbolt the whole front crossmember and bolt it in place of your 68 crossmember if you want.
Edit: check this out: http://67-72chevytrucks.com/vboard/s...34&postcount=4
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
#4 | |
Happy to be here
![]() Join Date: Mar 2000
Hey Is there a later model long bed that will fit and line up to my 1968 c-10 longbed. with or with out modification. thank you very much.
#6 | |
Laid Lo
Will it look like carp? Definitely. The only later model bed that has any sort of halfway decent looks on these trucks is the 87-98 short steps.
Semper Fi, Jeff ![]() '72 C10 - lays frame '07 Sand Rail - ecotec powered '05 2500HD - tows stuff '67 VW Bug - gas saver '01 Jeep TJ - rock crawler |
I know you said later model, but just wanted to clarify that 68-72 beds are all the same.
Junior Member
front disc conversion.... easy search.... its benn covered a million times. On going to a newer bed, I personally dont care for the look of it but 88-98 will work but you have to change the mounts to get the body lines to relativley match up.
I think these trucks look stupid with the newer body style beds...
Best Regards, Leon M. Instagram: @TheDirtyDianah
Bagged | 6.0L LS | T-56 (6-Speed Manual) | Turbo Burnout/Rolling Video: Chevy C10 Stepside 6.0L LSx & 6-Speed Manual |
![]() Join Date: Feb 2004
as stated you will need the spindles rotors and drag link and tierods from a 71- 72 . you also need to change the ball joints. now you can run a oe drag link but then you have to get custom tierod adjuster sleves (expensive) and also get new tierod ends caus they have to be boched together from diffrent years. thats what i did and trust me its cheaper to just find a donor and change the whold front suspension.
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
67-72 parts collector,…
![]() Join Date: Nov 2002
Buy year specific drop spindles.
Most aftermarket suspension companies sell a 63-70 standard spindle and drop spindle. They will be a direct bolt on. You don't have to change the ball joints or tie rods. This is the simpliest way to do it. Buy parts store rotors, calipers, brake hoses and M/C .
