Old 04-17-2003, 04:24 PM   #1
71sub
71sub's Avatar
Angry Hood won't "pop" open
I'm tired of having to sqeeeeeeze my fingers between hood and grill AND push up on the hood to get it to open. What do I adjust to make this work better ?
Also, the hood sits up near the cowl and I need to press down
for it to sit right --- is this do to the hood springs ?
71 C/10 : 350 / 700r4 ; Ford 9" posi 3.50 with 31x10.5 rear tires, single drive shaft, C-notch, 2.5" drop spindles, keyless entry
71 Suburban 350/350 -- caddy tail lights, keyless entry, late model seats, billet Autometer instrument cluster
70 Ford Torino -- 351W (balanced & blueprinted ), C4, VDO gauges
71sub is offline   Reply With Quote
Old 04-17-2003, 04:31 PM   #2
Mike Culpepper
Red
Mike Culpepper's Avatar
I have the same problem at the cowl but only on one side. I have seen posts here referring to a "trick" for the hood/cowl alignment prob. I'm interested in hearing from the experts.
Mike
'72 Cheyenne LWB 350/350
"The sun don't shine on the same dog's ass all the time." - Catfish Hunter (commenting on why he was not able to pitch another perfect game).
Mike Culpepper is offline   Reply With Quote
Old 04-17-2003, 04:38 PM   #3
jhow66
jhow66's Avatar
Try using some WD40,etc. on all pivot points.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 04-17-2003, 04:48 PM   #4
mtdave2
newly minted old timer
mtdave2's Avatar
the popping up in the back are worn out hinges.. get some new ones!
for the pop up...? wd40 like johow66 said..
72 c20 longhorn 65k org miles and counting!
69 k10 Suburban
mtdave2 is offline   Reply With Quote
Old 04-17-2003, 06:23 PM   #5
tom hand
CCRider
tom hand's Avatar
Well I would say buy some new hinges. It will solve both problems. I could not believe the difference when I put them on mine. I reused the old springs and I have to hold my hand over the hood when I pull the latch to keep it from popping all the way open.
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 04-17-2003, 06:38 PM   #6
72MARIO
72MARIO's Avatar
GM sells them.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 04-17-2003, 06:46 PM   #7
cdowns
cdowns's Avatar
some penetrating oil on the hinges and clean the latch real good with wd40 then a little grease on the latch will make a BIg difference
Old 04-17-2003, 07:04 PM   #8
71Blazer
Goodbye Darlin'
71Blazer's Avatar
What shape are the front corner hood bumpers in? With new bumpers adjusted to the right height my hood now closes with a nice "click" and pops up just 3" or so when I pull the latch.
I had the hood off and had a hell of a time getting it to close right. Spent a lot of time readjusting the position of the hinge/spring assm. where they bolt to the body. Good Luck!
1971 Blazer CST SOLD!
71Blazer is offline   Reply With Quote
Old 04-17-2003, 07:10 PM   #9
71sub
71sub's Avatar
THANKS for all the input.
I've cleaned the latch mechanism pretty good and it closes with a
nice click ---- but it just won't pop open when I release the latch.
I'm going to replace the hinges -- got them new this afternoon.
Any ideas on how to remove old hinges and install new ones ?
Old 04-17-2003, 07:46 PM   #10
Tynee
I miss this truck.
Tynee's Avatar
PM Huck or search something like "Merry Christmas" He went through a good process for adjusting your hood hinges, but it's been a while back. Sometime around Christmas. I'd at leasst try that before I spent MOney on new hinges. Just a suggestion.
'07 GMC Acadia SLT. Sweet ride.
'08 Crew Cab Z-71 short bed. Really like this truck A LOT.
Tynee is offline   Reply With Quote
Old 04-17-2003, 09:04 PM   #11
Project1970
14.1 @ 96MPH
Project1970's Avatar
It's supposed to pop? I've always just used one hand on the latch, and the other arm to push the hood up a bit...of course, I've got plenty of room for arms in that GMC grille...
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
Old 04-17-2003, 09:30 PM   #12
Huck
Huck's Avatar
If your hood hinge pins are worn real bad---this might not work but---
Each hinge has 5 points of attachment---two to the hood and 3 to the fenders. The 2 hood attachments allow for forward and backward adjustment of the hood against the cowl or grill. The 3 hinge to the fender provide adjustment of tension of the hinge spring.
Assuming you have the hinge to hood alignment adjustment ok, then by loosening the hinge to fender, you open the hood all the way and then push it up a bit more which forces the hinges to pivot a bit more. Then you need to tighten the hinge to fender bolts.
This is really a two person job unless you are real creative.
Even well worn hinges have been adjusted like this with great results. The only time it didn't work for me is when the hinge was so worn one of the hinge pivot pins actually fell out!!
To get your hood to pop open, the front latch needs to be just right with no bind of the hood to the grill or fenders. You adjust the latch mechanism via the hood pin four bolt mounting on the hood. Good luck---Huck
Huck is offline   Reply With Quote
Old 04-21-2003, 12:16 PM   #13
71sub
71sub's Avatar
Thanks Huck ! awesome information ... I'm going to give this a try before trying on the new springs.
Old 04-21-2003, 04:12 PM   #14
GMC JUNKIE TOO
THE QUICKER FIXERUPER
GMC JUNKIE TOO's Avatar
how much do a new set of hinges go for?$$$
GMC JUNKIE TOO is offline   Reply With Quote
Old 04-21-2003, 04:16 PM   #15
71sub
71sub's Avatar
About $9 / spring from The Truck Shop in Orange, CA
www.truckandcarshop.com
Old 04-21-2003, 04:24 PM   #16
Long Knight
Spank 'em if you got 'em!
Long Knight's Avatar
Do the after market hinges work alright?
Long Knight
'71 C-20, 350ci, TH350, Edl. 1406 Carb w/elec.choke, Ignitor ignition, Viper Tires, Orange Dipstick
Long Knight is offline   Reply With Quote
Old 04-21-2003, 04:27 PM   #17
stllookn
Saving 1 truck at a time!
stllookn's Avatar
New springs won't help. I have always found it is the pins...when they are sloppy and worn (both the pins and the brackets) they pull the linkage bars together like a scissor lift and lift the back of the hood. Huck is right but I have had trouble getting that method to work well for me. I have also elongated the mount holes vertically with a die grinder, then adjusted them donw as far as possible and tightened them in place.
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
