11-05-2011, 07:23 PM | #1 |
house of chevy's
front suspension ?
Ok so i have an 81 c10 from what i can tell it was lowered with drop spindles and coils cut my prob is a bout an inch around the inside of the front tire is wirn real bad and the rest of the tire is fine im gussing my tires are toed in at the top to much not sure how to fix it any help would be great thanx
1987 m1028 cucv d30 2001 chevy s10 2000 honda shadow sabre 1100 "it's going to be an interesting ride home" |
11-05-2011, 07:31 PM | #2 |
It's Better With Nitro
Re: front suspension ?
It sounds like you have too much negative camber. It would be best to take it to an alignment shop if you are not familiar with setting up your own alignment. Typically, the negative camber is addressed with shims for the upper control arm, but there could be other issues going on.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
11-05-2011, 07:53 PM | #3 |
house of chevy's
Im just tryin to get an idea before i bring it some where so i have an idea whats goin on
11-06-2011, 03:38 PM | #4 |
sounds like neg. camber to me . toe is in or out of the front of the tires when viewed from the front, camber is leaning in or out when viewed from the top.too much either way of either angle is terrible for tires
11-06-2011, 03:40 PM | #5 |
an important note when you go to the alignment shop, if any of you're suspension or steering parts are worn out they probably won't align the truck .
11-06-2011, 04:32 PM | #6 |
house of chevy's
Ok so do they add or take out shims in the front to correct it when aligning it
11-06-2011, 05:11 PM | #7 |
house of chevy's
Another ? While its on my mind how do u check if a the front end componets are good like ball joints and tie rods thanx
11-07-2011, 06:31 AM | #8 |
house of chevy's
No one come on guys
11-07-2011, 06:42 AM | #9 |
One way to check is to see if there is extra play on the joints, torn grease boots
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
11-07-2011, 11:09 AM | #10 |
Have someone hop in the driver's seat and turn the wheel just a little back and forth slowly and look at each "joint" If one moves and the other doesn't, Its probably bad.
Now, jack up the front end and have someone push/pull on the tire looking for play or movement. I recently replaced my gearbox and pitman arm because of the play in it. I couldn't find it by myself, but with the help of someone else turning the steering slowly I found it. Drives MUCH better now. |
11-07-2011, 06:36 PM | #11 |
house of chevy's
Thanx
