04-17-2003, 08:08 PM | #1 |
brake hoses
does anyone know what front brake hoses i need for a disk brake front on a 69 half ton. i don't want to change all the steel lines and i know some one else has already ran into this problem.i am useing 73 drop spindles and would like to use the original rear hose hook up points on the cross member. thanks snow man
04-18-2003, 07:48 AM | #2 |
surely someone has the done this
04-18-2003, 08:32 AM | #3 |
Not real sure what you are asking. I just changed out every thing on my 72, all new S.S lines and hoses. If you are changeing it out to 73, I would think you just get the hoses for a 73 truck. Unless I am not understanding what your asking.
Sam
72 LWB chevy truck. Pasadena, Texas |
04-18-2003, 10:28 AM | #4 |
R U want ing to run the brake lines on the back of the a-arm or front or are u talking about the rear brakes?"??????I think the front brake hoses have a different type of connection on the caliper 72 to 73.If you have 73 front then u need 73 hoses
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
04-18-2003, 03:50 PM | #5 |
brake lines
73 calipers but i am wanting to use the stock mounting that is on a 69 which is on the back side of the crossmenber. the after market 6 lug rotor kits are set up to use the original mounts but i need to know how long the hoses need to be. thanks snow man
04-18-2003, 10:04 PM | #6 |
Early Classic Enterprises sells hoses to connect calipers to fittings on back of crossmember.
68 Short Stepside, 350, quadrajet, 700r4, 3:73 posi, power front discs, HEI, Factory Air, Tilt, Tach, accelerator cable instead of rod, sway bar. 96 Impala SS 97 Monte Carlo |
