04 burb leaking coolant from somewhere
It's only got 150K on it
![]() I also notice the sweet smell when I get out of it during the day too. No moisture around the hoses and I didn't see a pet cock valve to check, but I just did a quick glance. It's right in the middle of the vehicle in the front. Haven't removed the shroud to check the radiator, just thought I'd throw this out there. Also, is there a way to pressure test these things? I didn't see a radiator cap anywhere, just fill it up through the resovoir. Thanks all...
1st - '68 long bed 2nd - '81 SWB Now - '86 SWB, Edelbrock 1406/stock 350/700r4 |
Re: 04 burb leaking coolant from somewhere
Water pump gaskets.....Seen it hundreds of times, Its also happened to both my 04 5.3L engines.
Whens the last time you replaced the water pump?
Most water pumps on these engines are replaced because of the pump to block gaskets are leaking.
In my opinion transmissions, fuel pumps, blend door motors & insterment clusters go out more than the actual water pump. |
#5 | |
![]() As for replacement- |
Never. Haven't replaced anything on it like that (knock on wood). Didn't even think to check that out. Used to being able to trouble shoot my '86 with a little more ease.
So what kind of job am I looking at replacing this thing?
Well, the video showed him doing it in about 15 mins so I figure I'll be good
![]() I appreciate the info. Looks like I've got my work cut out for this weekend!!!
Waterpump gaskets are a breeze in these newer trucks.
While your coolant is down take off top hose and put a little tube can of preston fix or Barrs Leak in it and follow instructions. It will stop the leak... IF YOU CAN'TT FIND LEAK....
