11-09-2011, 11:14 PM | #1 |
trailer fender wheel tub question?
Is it possible to weld in trailer fender wheel tubs while keeping my factory ac? Or is the ac box going to be in the way? Please help and pic would do me great, trying to get this done but was told I couldnt with ac box......can y'all help?
Posted via Mobile Device |
11-10-2011, 01:17 AM | #2 |
Re: trailer fender wheel tub question?
It would depend on how low the truck is going to be & how tall the wheel/tire combo is.
11-10-2011, 03:21 AM | #3 |
Depends the year truck but vintage air and classic auto air both have ac kits that are fully under the dash.
11-10-2011, 08:31 PM | #4 |
Well the truck is bagged and its a 86 c10. I planned on 22's. Truck doesn't lay frame cause I didn't want my bed cut up, so aired out I sit about 3 inchs off the ground.
11-11-2011, 07:26 PM | #5 |
Anyone?
11-11-2011, 08:32 PM | #6 |
AIRBAGPARTS.COM
If you want to lay the front out, then yes the AC unit will be in the way. If you don't mind just bottoming out on the front wheel wells, then just make them as high as possible without interfering with your AC.
11-12-2011, 04:00 AM | #7 |
Yeah what jason said will work.
11-12-2011, 03:44 PM | #8 |
So with that being said I take it that the weight of the truck won't bend the welded in trailer fenders when bottoming out?
11-13-2011, 01:17 AM | #9 |
As long as you put them high enough the wheel can't touch them you won't have to worry about it.Some i have seen took the stock inter fenders and cut the top off and made them taller so it looked more stockish.
