would fuel injection solve my cold start problems?
I have a 1970 C10 with a 350/350 combo. I just recently put in a new Holley Avenger carb, and have it tuned to the best of my ability. It is still very cold blooded in the mornings (temp around 30-35*). Once it warms up it runs pretty good, but first thing I can't even get it into gear without dying. I may need a new electronic choke assembly because I can't seem to get the fast idle circuit to set with the choke before start up unless I move it by hand. At the end of the day the question is if I put in one of the TBI conversions like the one from FAST, or Holley, will that solve my cold bloodedness, and driveability issues? Timing is dead on. Float levels are perfect. It's just been a long time since I have fidddled with a carb, and would like to solve the problem without wasting a bunch of time. Ideas????
Active Member
Re: would fuel injection solve my cold start problems?
I am not sure that it will solve your issue - I just read a review of one system that is on the market - I wish I could remember which one - but that was really the one issue that they had was cold start up - very suprising to me
I really want to go FI - I think it is worth some HP and really helps the drivability and fuel mileage.
1968 SWB 454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts 781 heads Ported with 2.19/1.88 SSTvalves Lunati 60204 cam, Micro Trol lifters, Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition Holley 770 Street Avenger carb,Headers armor coated Built by Watson Ruppel Performance in Sarahsville Ohio. Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall 12 Bolt Eaton Posi 4.10 Richmond Gears moser axles ![]() 18.5" x 31" Hoosier Pro Street Radials ![]() ET Classic 5 Wheels - polished Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone) Custom Paint & Body Work Special thanks to my wife, my son and my money tree ![]() |
#3 | |
![]() Join Date: Feb 2007
My little experience with aftermarket efi multiport systems including Holley and Edelbrock's pro-flo systems. EFI systems do not create more peak horsepower per say, but do provide an opportunity to the tuner to build better under the curve torque and power through the tuning maps. I've found this to be true with both stand alone fuel map systems and full fuel/timing control systems. You are definitely correct on the driveability and fuel consumption aspect so long as a guy's tuning capabilities are up to par. If they are not, as I unfortunately found through hands-on-learning, a poorly tuned efi map will create more issues and worse performance for the user than a poorly tuned carb both in terms of performance and lack of security of knowing where the problem lies. What little time I have spent tuning on dynos I have found that what produces impressive numbers (thus marketing and selling points) does not cater to driveability needs. More often crank dyno friendly numbers tend to be found through overly lean, under gased, and overly timed parameters compared to real world, on the street, work loaded comparisons that are not catering to controlled atmospheric conditions. Unless a guy is looking to run their rig upside down, (from my experience ![]() ![]()
Steve 1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's |
I installed a Holley avenger MPFI on my 350 about 6 months ago. It fires right up and doesn't stall when cold. It does have all the benefits of a modern FI system in terms of drivability. There are some settings that can help control cold start problems as well such as "coolant enrichment" which can increase or decrease fuel delivery during warm up to prevent stalling.
For reference, I have a 700R4, 4.1 rear end, and 32" rear tires. I cruise at 65 mph, ~2050 rpm, and about 15 mpg. The avenger is self tuning, in that it will get the engine up and running well quickly, but fine tuning is still required for optimal performance. I am still trying to fine tun the timing map. |
Properly adjusted choke would cure your issues. Should start right up and drive away at -15*.
I would keep on tuning.
__________________________________________ Sean 1972 C20 2005 4Runner ![]() |
Yes, FI should greatly help cold start issues. No more pumping the pedal, setting the choke, waiting, flooding, etc.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
i was having this problem with my edelbrock 600 in all weather, i just put an electric choke on it and now it fires up with the slightest bump of the key and runs like a top
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308 2014 Chevy 2500hd duramax CCLB |
![]() Join Date: Jun 2010
You should be able to tune the carb and get it to run well on cold starts. I know down here we don't get near the cold ya'll do but it still gets cold on occasion. The best way to tune it would be to tune the main circuits of the carb during the middle of the day with the engine warm, then later that evening tune the choke circuit when the engine and ambient air temp. are cold.
Eat, Sleep, Drive a Chevy
Before there was fuel injection there were cold days. A choke was what we had and we used it...sorry grandpaw kicking in
yes, fuel injection would help with your problem but do you really want to spend that kind of money only to fix a cold start issue? good luck
Trey Silence may be Golden, but Duct Tape is Silver! 72 Short Step 57 "big window" short step |
A properly set up efi system will start great. A properly set up choke probably will also. I have efi from a 92 camaro except with a holley stealth ram intake. Sometimes (in winter) its not started for over a month and will fire right up.
I think there is something wrong with the choke. It seems that the fast idle cam does not set with the choke unless I manually flip it. I may just get a new choke assembly and try that.
