Old 11-11-2011, 03:34 PM   #1
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Any 72 trucks optioned with factory aux tank and in-bed spare holder?
I may add the aux tank option to my 72 and already have the in-bed spare tire holder. Not sure if the location of the fuel neck/bracket interferes with the spare holder. Don't think so but haven't seen a truck optioned this way yet.
Old 11-12-2011, 10:38 AM   #2
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: Any 72 trucks optioned with factory aux tank and in-bed spare holder?
Anyone seen a 72 truck with both these options?
Old 11-12-2011, 10:02 PM   #3
Auxiliary fuel tank was a factory option. In-bed side-mount spare was a dealer accessory. I don't know if the auxiliary tank filler is forward enough to clear the tire mount. They weren't engineered to work together as if they had both been factory options.
Old 11-13-2011, 09:54 PM   #4
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
My truck had this. Factory installed. On SPID. "P13 S M WHEEL CARRIER"
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline   Reply With Quote
Old 11-13-2011, 12:55 AM   #5
DeadheadNM
Carpe manana
DeadheadNM's Avatar
I didn't realize the in-bed spare was a dealer accessory. I've seen them painted to match the bed so assumed it was a factory option but I suppose that could be done at the dealership. Guess that means it could also be mounted on the passenger side?! Thanks for the reply.
Old 11-13-2011, 01:00 AM   #6
Maybe I'm wrong,but I don't recall ever seeing tone listed as an option.
Old 11-13-2011, 02:22 AM   #7
SS Tim
SS Tim's Avatar
That would be RPO P13 for a factory installed carrier. Also available as an accessory and aftermaket. I've seen them factory mounted only on the left front. Also have period pictures of twin mounts (left & right). My '72 Custom/10 had an aftermarket in the left rear. Worked out pretty good too. Out of sightline and a place to stash stuff around. The data book does not show a restriction for the side mount carrier P13 other than Fleetside or Longhorn. The aux tank NL2 was available on 20-30s Fleetside or Longhorn. As I recall the carrier was T shaped and bolted to the inside top bed lip and down through the floor. If the fill pipe cover is flush with the rail, then they should fit fine together. In thinking about it I'd imagine most people wanting more fuel would go for the dual tank set-up, either accessory or aftermarket.
SS Tim is offline   Reply With Quote
Old 11-13-2011, 01:47 PM   #8
This makes me think there is a restriction. In fact,wouldn't it mean it's for a Stepside?
I should have thought a little more before answering the mount was an accessory and not an option. But,I have never seen the combo before and,even though the duct for the aux.tank filler sits flush with the inside of the bed rail,the issue would be whether the duct is located forward enough to not interfere with the "T" of the mount. The tire mount needs to sit forward enough to allow room for the tire in front of the wheel house...especially with a taller 3/4t tire.
Old 11-13-2011, 01:56 AM   #9
DeadheadNM
Carpe manana
DeadheadNM's Avatar
It is a factory option # P13.
I gather this combo of options was either very rare or not available at all.
Old 11-13-2011, 10:04 AM   #10
DeadheadNM
Carpe manana
DeadheadNM's Avatar
That's helpful info Tim. Thank you.
Old 11-13-2011, 01:58 PM   #11
DeadheadNM
Carpe manana
DeadheadNM's Avatar
I'm pretty sure P13 was the option on a fleetside. Not sure if same was used for step side.
It's the bracket fitment in the anterior-posterior dimension that I'm most curious about. I'll crack the assembly manual and see what I can dig up but I haven't figured out yet how that book is organized.
My K20 bed already has the spare mount and I've collected the parts for the 72 aux tank (more or less) and really want to install both. I'll likely install an aux tank regardless but would prefer to do a "correct" factory 72 type install (I've got the 70 between frame fleetside aux tank parts too).
Old 11-13-2011, 02:12 PM   #12
Richardwa
Active Member
I have a 71 GMC fleetside with the factory aux. tank, I can take some pics when I get home from work if that will help you any
Richardwa is offline   Reply With Quote
Old 11-13-2011, 03:25 PM   #13
DeadheadNM
Carpe manana
DeadheadNM's Avatar
That would be a big help especially with a tape measure from the forward bed edge to bracket center or from some other fixed reference.
Thanks guys!
Old 11-13-2011, 08:01 PM   #14
Richardwa
Active Member
Thanks guys!
OK< here are some pics, if you need more let me know
Hope these help
Old 11-13-2011, 03:12 PM   #15
SS Tim
SS Tim's Avatar
P13 was also the code for Stepside trucks, but was a completely different exterior mount setup. I was sticking to Fleetside info for clarity.
Anyway, here is a parts link with info and pictures that is sure to help.
http://67-72chevytrucks.com/vboard/s...d.php?t=334223
Old 11-13-2011, 08:15 PM   #16
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Thanks a lot! Looks like the two brackets will not interfere with each other. I really appreciate the help.
