11-11-2011, 06:33 PM | #1 |
6.2l or 6.5l diesel
How can i definitely tell if i have a 6.2l or 6.5 l in my suburban? Its a 1986 which should be a 6.2, the owner swears its a 6.2.....but the valve covers say gm performance 6.5
how can i tell for sure there wasnt just a valve cover swap? |
11-11-2011, 06:52 PM | #2 |
Re: 6.2l or 6.5l diesel
Don't really know much about either engine, but find the casting number on the back of the block and then google it. That will tell you.
1955 Chevy 3600 http://67-72chevytrucks.com/vboard/s...61#post8589061 |
11-11-2011, 07:56 PM | #3 |
6.2 and 6.5 valve covers are the same, check the heads.
1983 GMC Sierra K2500- The Rat 1986 Chevrolet Silverado C10- The Donor The DD: 1999 Chevy S10- 4.3 Vortec, 5 speed, Ext Cab Last edited by OnDaTrail; 11-11-2011 at 08:02 PM. |
11-11-2011, 08:34 PM | #4 |
check the numbers on the rear of the block
11-12-2011, 09:40 AM | #5 |
Isn't all 6.5 turbo and the 6.2 isn't?
11-12-2011, 09:57 AM | #6 |
from what ive read the 6.5 was usually turbo....but the suburban was originally a 6.2l nonturbo
ive also read that in the 90's they sold 6.5l as replacement motors for the 6.2ls since they were bolt in replacements and were being mass produced at the time so it looks like ill have to check the block casting numbers - the only reason im really asking is i hve a friend who has a turbo for a 6.2l, which supposedly wont work on a 6.5l |
11-13-2011, 12:43 AM | #7 | |
1990 ¾ ton 4x4 Chevy Suburban -Cummins Diesel - 12 valve - factory rebuilt -6 speed bullet proof manual transmission - NV5600 -Gear Vendors Overdrive - HX35 Holset Turbo -NP205 iron transfer case -3.73 gears -2" Lift |
11-14-2011, 01:03 PM | #8 |
Gentleman Jim owner x2
Look on the front right part of the engine right behind the water pump housing. If it's a 6.2, it'll be stamped GM 6.2L D.
Not all 6.5's were turbo'd. Just most of them. There's too many variables to reliably tell you just by looking at one piece of the puzzle. If you want to beef up your engine and help it out on the bottom end, look into getting main girdle studs (similar to head studs). They really help a lot with being able to hold extra compression from a turbo, and bottom-end longevity in general.
1975 GMC Gentleman Jim #1 -357 / 700r4 1975 GMC Gentleman Jim #2 -350 / TH350 |
11-16-2011, 12:40 PM | #9 |
The 6.5 TD injectors are angled and shorter to clear the turbo, where the 6.2 has longer injectors and are straight (perpendicular to the head). I'm in sure if tge 6.5 NA heads are the same as the TD though....
CHEVY ONLY |
11-16-2011, 02:53 PM | #10 |
Don't forget that sometimes it depends on what vehicle the 6.2 came out of, too. Vans had shorter injectors than a standard 6.2... just wanted to throw that out there.
11-16-2011, 03:02 PM | #11 | |
But I don't know if all 6.5's have angled injectors. And since the heads will interchange you would really have to check the block to make sure what it is. I don't know of a clear advantage between a 6.5 and a 6.2 if you take the turbo out of the equation. Keep in mind that I'm still fairly new to these engines and trying to learn all I can,but I'm definitely a detroit diesel convert Oh, and I also read that the 85-up 6.2 injectors will swap with the 6.5 injectors, I have no real world experience with it yet though Posted via Mobile Device
CHEVY ONLY |
11-16-2011, 03:57 PM | #12 | |
11-16-2011, 03:59 PM | #13 |
Good to know!
Yeah the threaded holes in the 6.5 heads are angled Posted via Mobile Device
CHEVY ONLY |
