![]() Join Date: Apr 2011
Gas tank filler hose?
Swapped in an aftermarket '87 20-gal tank (with baffles) to replace my 20-gal carb'd tank and the old filler hose pipe is a smaller diameter than the inlet to the new tank. The hose pipe is prob. as old as the truck (1980) and is thus hard as a rock. Is that the reason why it doesn't fit, or did the '87 tanks come with a bigger inlet diameter, or is it because I'm running an aftermarket tank?
Need to know because I want to go ahead and order the part from LMC, but don't know if I should order for a 1980, 1987, or not at all?
-Steve ![]() 1980 GMC C15 Sierra LWB Dark Carmine Red/Carmine Int Was: 250/3spd (1980-88), then a 305/TH350 (1988-2011) Now: 5.3/4L60E, 2.73 12-bolt open rear |
Re: Gas tank filler hose?
Well the '87's were TBI, I imagine that has something to do with it. Totally different system.
Steve Member of the Foot Pedal Club '83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL, Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws, 350 HP 350 crate engine from Jegs, Turbo 400 ![]() |
In the Forgotten far North.
![]() Join Date: Jul 2007
I'll check at work today and let you know tonight on availability of oem parts.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
#4 | |
Cool, thanks for your help!
Just did a swap of an 84 tank into my 77. My 77 has a inlet hole of 1 and 1/4 inches and the 84 is 1 and 5/8. I believe 82 and up were 1 and 5/8. Check ebay for 87 gas tank and usually they say what size the inlet necks
Michael Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9 |
Thanks for that...for some reason I didn't think to check the diameters of the different tanks (I still have my old tank kicking around) with my calipers
