11-15-2011, 05:58 PM | #1 |
Center Caps
Where can I find factory replacements for rally wheel center caps?
1972 C10 SHORT BED, BLACK ON BLACK, ZZ3 CRATE MOTOR WITH B&M 250 SUPERCHARGER, HEADERS, 350TURBO TRANS, BOOST RETARD, POSI, 373 GEARS 1966 MUSTANG COUPLE, 289 HIPO MOTOR, CAM, 650 HOLLEY CARB, FULL LENGTH HEADERS, 2.5" FLOWMASTER EXHAUST, HURST SHIFTER, 373 GEARS POSI 2006 MONTE CARLO, FLOWMASTER MUFFLERS, K&N INTAKE, EXTERIOR MODS |
11-15-2011, 06:08 PM | #2 |
Frequent Flyer
Re: Center Caps
I'd say ebay or check with any of the common vendors like LMC for some repops.
Have you ever thought of going to the late model caps on them? |
11-15-2011, 06:18 PM | #3 |
Re: Center Caps
I like those better, what year are those off of? Also do those just fit right on?
11-15-2011, 09:33 PM | #4 | |
Re: Center Caps
An alternative is to tap the back of the caps & screw in some screws through the original mounting holes ralleys had for the older 73-87 caps.
11-15-2011, 09:35 PM | #5 |
Frequent Flyer
Re: Center Caps
They are off of the 88-98 sport truck wheels. Then I found a guy to makes different colored decals for the centers.
Installation is pretty simple. They are attached from the back side. There are little tabs on the back of the caps you can thread a screw into, you put the screws on from the back of the wheel going thru the hole in rally for the bolt that hold on the earlier style cap. They are off wheels like these... |
11-15-2011, 10:02 PM | #6 |
Re: Center Caps
I've looked at replacement centres through LMC, Brother's etc and they want $30 for EACH centre. That can't be right can it? All they are is a decal.
