04-18-2003, 09:08 PM | #1 |
HMMMM Chevy
flipped shackles?
I found these and was wondering if anyone has used these.
http://www.off-road.com/chevy/review...ins3_small.jpg found them here
68 Chevy C10 swb(under construction) 82 GMC K1500 6.2l diesel (daily driver) 77 Chevy K30 frame (only thing left is axles and trans/transfer)______________________________ Mike |
04-20-2003, 04:45 PM | #2 |
Giddy up giddy up...
Just torch a hole in the bottom of your existing hangers, flip the shackle, and you've got a four inch lift.... ok, well, there's a little more work involved than that, but that's what I did and worked great. Just make sure to add some braces after for the lost support. FREE is always a good price
72 with 69 grille and custom 73-87 stepside. BIG BLOCK 409, SM465, NP205, 3/4 axles slung under a 5" lift, 3"bodylift, 112" frame, and 35inch Pro Comp X-terrains... "BUILT NOT BOUGHT" Here's the site... |
04-20-2003, 09:31 PM | #3 |
Yukon Jack has the shackle reversal on his 3/4 ton and is quite happy with them. I'm sure he'll chime in here.
I recommend new springs, however.
04-20-2003, 11:02 PM | #4 |
I have something very similar, the Echobit shackle flip. It rides better than simply lifting the rear with springs.
I like it and would recommend it. -- Mike
http://home.houston.rr.com/chevy73/ |
04-21-2003, 01:55 PM | #5 |
That looks like the shackle flip from www.offroaddesign.com that I am using. I'm pretty happy with mine but beware that your rear axle moves closer to the front of the rear fender well.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
04-21-2003, 07:02 PM | #6 |
HMMMM Chevy
ok i have 31's on the truck now. but if the axle moves forward would I be able to get the 35's on the truck. what size you have under your truck Yukon Jack?
04-22-2003, 09:43 AM | #7 |
Originally I had just the shackle flip gaining 4" and the 35's fit fine.
