Truetrac does not offer in a 3.42 carrier. 3.73 up is all.
Hesitant of 3.73's due to 80% highway driving Hesitant of a posi as the locker in it is broke now 468, th400 and 29x20x15 mickeys. What to do? Posted via Mobile Device |
![]() Join Date: Feb 2001
Re: No truetrac / 3.42 combo! What now?
ttt
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
www.auburngear.com
Your old posi probably broke from improper maintenance. But,the Auburn is a stouter design I think.
how old is the posi you have now that is broken?? if its a 40year old piece? i'd think it gave great service over that span
#5 | |
This is for a 12-bolt 30 spine? I found a listing for 3.73-down carrier:
http://www.currieenterprises.com/ces...E.aspx?id=3337
Yes and correct but thats for a car
What you have now sounds like a Gov-lock. They are famous for breaking because they use centrifugal weights to engage, or lock.
I would run an Eaton LSD. They're very durable and rebuildable. The Auburn LSD's are great units, but they're not rebuildable http://www.ringpinion.com/b2c/Produc...and=Eaton_Posi
#9 | |
Eat, Sleep, Drive a Chevy
Trey Silence may be Golden, but Duct Tape is Silver! 72 Short Step 57 "big window" short step |
Ttt
I'm wondering if 3.73's will be too much but I am leaning that way to get the true trac.
Oh yea, the busted LSD is a powertrax. One of the pins is jammed in there. Posted via Mobile Device |
Has more rust than truck...
Powertrax is far from the strongest locker out there. Most cases a different area of a 12 bolt will give up before a Eaton posi will..
So which of the following gears do I get? 3 or 4 series carrier with a truetrac?
http://www.summitracing.com/parts/RMG-4902801/ http://www.summitracing.com/parts/RMG-4900721/ Posted via Mobile Device |
Give DTS a call they will get you you need plus more and at a fair price.
browse through the web site. they even carry the x-tra thick gears for different series carriers to fit each other. example 3.08 gear fit series 4 carrier. ![]() www.drivetrainspecialists.com |
#15 | |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
http://www.drivetrainspecialists.com/index.html
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
#16 |
I had a 3.73 gear with 28" and 29" tires. It was ok, but trying to drive 70mph on the interstate wasn't alot of fun. I finally switched to a 3.07 this spring. I lost some bottom end, but it's great to be able to drive in the fast lane with other traffic. I personally wouldn't go 3.73's if you do alot of highway driving. Unless, of course, you don't mind staying at 60 in the slow lane the whole time.
#17 | |
#18 |
The 468 seems pretty built as I don't shift til 6k.
#19 |
Went with truetrac and 373's. Should keep those 15" wide mickeys going.
#20 |
#21 |
If you go a little taller on your tires it will drop ratio a bit. when you need new tires of course. I am running 373's in my Jeep with 33's does good on highway. Went with 373's in My 70 GMC4x4 with 33's also.
Ron Ron
Member #111 68 C-10 ![]() 70 ![]() 76 Jeep CJ-5 Help Support the Board: http://67-72chevytrucks.com/vboard/payments.php He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors. Thomas Jefferson |
#22 |
Yep. I'm a 2 wheeler though on bags. Tow vehicle has 35"s though. Thanks for the input. Other set of wheels has 31".
#23 |
Like it. I have a three speed so it runs over 3k at 75 bbc.
#24 |
I probably will go with that as well, my tires are 28.5" tall, and will probably be just over 3K @ 70-75.
Thanks |
