sbc location in S10 frame
Has anyone here mounted their engine and tranny before the cab is mounted? I just wondered if there were any reference points on the s10 frame that could help with location, also the tranny cross-member. It would just be easier without the cab on.
#2 | |
Re: sbc location in S10 frame
![]() Maybe someone else has a measurement for you, but putting the cab on is a lot easier than redoing the mounts down the road (especially after the frame is painted). Last edited by DransportGarage; 11-18-2011 at 10:31 PM. |
DransportGarage
You are so right, I know that the easiest way is definitely not always the best way. I certainly don't mind setting the cab and doing it first so as to prevent those potential problems you mentioned. It just seems that most everybody here is fairly consistent with their measurements like missing the firewall by 1 to 2 inches and so forth. Just thought that there might be a point of reference on the frame that someone had noticed. Thanks for all the valuable info here .... All yall are great |
Old Heap Driver
Speaking from experience, mount the cab first. I positioned my cab and front fenders (with tack welds on the mounts) where I needed them on the chassis. After mocking up the motor position I blew everything apart and welded up the motor mounts. The process was time consuming but gave me the results I wanted.
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. |
