11-19-2011, 08:03 PM | #1 |
Trailing Arms From Scratch
I'm going to make some out of 2x2 box tubing, but would like to know what people have used on the ends?
Is there a kit? Are people just using bushings? Are some using Heims? Has anybody ever used the ends off of the leaf springs? |
11-19-2011, 08:08 PM | #2 |
Re: Trailing Arms From Scratch
Member Nuke1 built custom arms for his truck and did how to:
http://67-72chevytrucks.com/vboard/s...d.php?t=321100
Nick Carter 1967 C10 Short bed Fleetside Project Cheap Thrills! 2WD C10 Modern/Performance Alignments Easiest Alignment Ever! |
11-19-2011, 08:26 PM | #3 |
Damn, nice TA's!!
11-19-2011, 08:28 PM | #4 |
Also, since my son's truck was a leaf setup, if I find a pair of TA's from a 70's model truck will those work?
(Truck is being bagged with a full notch) |
11-19-2011, 08:38 PM | #5 |
I think all the trailing arm from 60-72 are the same. So as long as you add in the trailing arm crossmember and a centering device (panhard rod, watts link) you should be ok. That is assuming it is 60-72.
