Old 04-19-2003, 07:38 PM   #1
Alexis
Member since 2000
Alexis's Avatar
Hei........???!!???
Well i had her back firing, and now there not even a spark, there is power running into her ,but no spark. what can it be?
Alexis is offline   Reply With Quote
Old 04-19-2003, 07:39 PM   #2
Dean23
68cst_ss490
Dean23's Avatar
the dizzy is in 180 degrees out, pull it out spin the rotor 180 and pop it back in
Dean
edmonton,canada
a winter wonderland
2005 Chevrolet Avalanche LT
cold air intake, performance exhaust, Comp cams cam, jba shorty ceramic headers.
http://www.cardomain.com/ride/3090973
Dean23 is offline   Reply With Quote
Old 04-19-2003, 07:57 PM   #3
Alexis
Member since 2000
Alexis's Avatar
Well let me tell you about todays HEi adventure.........When i had her back firing i thought it was 180 off so i got the thing to TDC and then i fliped her around. I puled out the plug and got a friend to crank it. No spark.......I had the edge of it on the head so it could have a negative. I stuck the tester in the wire plug and cranked it and nothing agian. ????
Old 04-19-2003, 08:00 PM   #4
rusty ol' 69'
Grubbin'
rusty ol' 69''s Avatar
If you can find one, get the plastic top that pops over the plugs to tell you which wire goes to each cylinder. Sometimes, you will encounter the problem your having just by having two wires switched out of order. Recheck the wires and top dead center on the dizzy and try again.
project rust attack 1969 Chevrolet LWB w/ 307. I got power steering now woohooooo!!!!!!!
rusty ol' 69' is offline   Reply With Quote
Old 04-19-2003, 08:29 PM   #5
Stroker
Alexis check the info at this link. They can do a better job of explaining than I can.
http://www.chevelles.com/techref/tecref5.html
Hope it helps. Good Luck............Stroker
72 SWB parts and pieces
Oklahoma
Stroker is offline   Reply With Quote
Old 04-19-2003, 08:34 PM   #6
Alexis
Member since 2000
Alexis's Avatar
ok is the harmonic balancer suppose to point to "0" on that little dial thing thats mounted to the motor or straight up? just so i can clear this thought out of my head.
Old 04-19-2003, 08:40 PM   #7
Stroker
If your balancer and tmming tab are correct the 0 should line up. Also take out your #1 plug and hold you finger over the sparkplug hole when there is pressure comming out and the tab and balancer line up you should be at TDC for #1.
Oklahoma
Old 04-19-2003, 08:55 PM   #8
Alexis
Member since 2000
Alexis's Avatar
just foud out why it wasn't firing.....toasted coil. i replaced it and wala.......still need to work the timing situation out. My batterys dead so i got to wait for the starter help thing to recharge
Old 04-20-2003, 10:51 AM   #9
Blue Beard
Blue Beard's Avatar
Make sure the wiring on the cap is right.
On a stock point cap the #1 is not in the same spot as the HEI, and I've seen several people try to do it.
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 04-20-2003, 10:55 AM   #10
Jwill41
Jwill41's Avatar
#1 can be anywhere on the cap as long as the #1 wire goes to it when the #1 cylinder is at tdc.
http://www.picturetrail.com/jwill41
67 1/2 ton GMC short step side
68 1/2 ton Chevy long fleet side
72 1/2 ton Chevy Suburban
99 1/2 ton Chevy Suburban
founder (and only member) of the primer/clearcoat club
Jwill41 is offline   Reply With Quote
