11-26-2011, 11:25 PM | #1 |
Best radiator for AD truck with V8
I'm tired of repairing the leaks in my '53 radiator. What will cool my 283?
11-27-2011, 12:31 AM | #2 |
Moderator
Re: Best radiator for AD truck with V8
Here you go, this is what I'm going to use:
http://www.ebay.com/itm/Chevy-Truck-...t_16234wt_1396 Can't beat the price, you can also get a 2 row or 4 row for a little more or less.
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
11-27-2011, 02:18 AM | #3 |
i have a champion radiator in my suburban(but its the same radiator for the truck) and i really like.i was suprised of the quality for $210 shipped to my house. the only thing i had to do was to get the side mounting brackets cut and welded straight(cost me about $50 at a local radaitor shop to have changed) because the manual fans in a v-8 hits the radiator if you leave the champion factory welded side brackets at an angle.then i descided to go to an electric fan with a custom made shoud because i mounted my motor low. but i was still money ahead. because i have seen the same radiator at high end shop going $600 for just the radiator. it cost me $450 total with radiator, a custom made shroud,rewelding the bracket,getting an electric fan and buying a thermastic fan relay with sending unit.
11-27-2011, 10:01 AM | #4 |
xaircav
What engine mounts did you use in your AD? I am getting ready to install a 283 in my '48! I plan to use my stock radiator for now as it doesn't leak yet! |
11-27-2011, 11:43 AM | #5 |
I used the tubular crossmember that Classic Performance Products and others sell. My other complaint about the stock radiator is the small size of the lower hose fitting. I had to squeeze the lower hose down with the clamp (see picture) For what I've spent on repairs I could have bought a new radiator. These old timers are 60 +/- years old and the solder is brittle and heat/cool cycles and vibration cause them to sprout leaks.
11-29-2011, 05:11 PM | #6 |
+1 on the Champion aluminum. This is what I running in my LS1 powered 52.
My build project http://67-72chevytrucks.com/vboard/s...=1#post4158671 |
12-08-2011, 01:46 AM | #7 | |
im still thinking if i will be considering griffin because it is not as popular as champ rad. i also see ah radiator from partstrain but anybody from you guys tried that site? any comments or violent reaction from that site? Last edited by masterjohnson; 12-08-2011 at 01:53 AM. |
12-08-2011, 02:01 AM | #8 |
I am upgrading to a stock radiator out of a big truck. They use the same mounting holes as a stock 1/2 -3/4 ton but are taller and deeper (by 1"). Mine was flushed and pressure tested when it came out of the truck. The shrould came out of a late 70's early 80's GM something. I made side closures out of sheet metal.
10-25-2013, 09:58 AM | #9 | |
11-29-2011, 09:16 PM | #10 |
Will the champion radiator work on a 401 Nailhead?
Posted via Mobile Device |
11-29-2011, 10:36 PM | #11 | |
11-29-2011, 09:17 PM | #12 |
11-30-2011, 05:38 PM | #13 |
I'm not sure why they havent been mentioned yet, but the title says your looking for the BEST radiator... in my opinion, that would be a Griffin. the ONLY thing i have ever heard in regards to a negative thing about their radiators is their price.
almost $600, but you specifically were asking for the best... Can you get a comparable radiator for 1/2 to 1/3 of the cost, probably... but they have to be the best, or close to... I have a Griffin in my task force truck, and I would buy another in a heartbeat for another project, VERY well built, and fantastic to look at as well... you can order different filler neck positions... http://www.summitracing.com/parts/GR...-BXX/?rtype=10 |
12-08-2011, 10:43 PM | #14 |
We did one from PRC Hotrods, the are American made and the workmanship was outstanding. I have fired it up yet to see how the performance but I would suspect it to be good. Also the brackets didn't come attached so you can move it around a little before you bolt it in solid. I am not sure you can tell from the pictures but I actually set it into the mount pretty deep so I could get some more motor clearance.
http://www.prchotrod.com/ |
12-09-2011, 01:10 AM | #15 |
Geez missed the AD part, mine is a TF. Don't know if the AD big trucks had proportionately larger radiators like the TF.
12-09-2011, 11:47 AM | #16 |
Griffen has always made top of the line radiators that are equal to anything out there that I know of but you pay for them just like you would a Walker.
I ran a 2-1/2 ton core with my 1/2 ton tanks and had the shop change the inlet and out let on the radiator that I had in the 48 for about 20 years but it finally got to where it was too far gone to save. I've been looking at the Champions on Ebay but until now hadn't seen any feedback on them from anyone. Some guys may not like the look of the welded tank though. |
12-09-2011, 12:24 PM | #17 | |
12-10-2011, 12:47 PM | #18 |
I have about convinced myself to pull the trigger on a 4 row champion.
12-10-2011, 01:21 PM | #19 |
Do it! You won't regret it.
58 Apache short fleetside ona 64 chassis: |
10-25-2013, 09:51 AM | #20 |
10-25-2013, 03:01 PM | #21 |
Do the champions work well with ac? 2 or 3 row?
10-25-2013, 07:36 PM | #22 |
I have a champion in my chevelle with shroud and 2 elec fans, works great. Friend of mine has bought 3 or so from him, he has even custom made 1 for him.
10-27-2013, 11:22 AM | #23 |
You won't need more than a 3 row champion.( It bolted in my 51 js like a glove)- have a problem with it running - get this - to cold. Ran a 150 mile trip yesterday- it refused to get above 170- even in traffic. My little 250- was sneezing like a kid with a cold. (I was in the same exact spot you were). 188$ later I am certain that I made the best choice.
10-28-2013, 07:50 PM | #24 |
have had a champion in my 52 for 2 years ,went right in, works super.
Fatbear 1952 yellow 3100 350 v8 on sonama frame |
