Old 11-29-2011, 05:12 PM   #1
54belair
54belair's Avatar
Identifying a 12 bolt rear end
With my recent purchase of a 68 project came a complete (but unassembled) 12 bolt posi rear end.
The only info I can get about the rear is that it was changed out because the posi unit "kept going out"
I have found both casting no.s and stamped numbers that are in the pass. side web or on the pass side tube. So far I havent been able to id the numbers.
If anyone can help---Id sure be appreciative!
Cast numbers are (in web) NF 3896838
stamped numbers are: HA 06 05 W 2
the stamped numbers are widely spaced in the order im showing
NUMBERS in the carrier are 326663 ngm51 c3
Ive looked for a data base that might show what the housing and center cection is from but havent had any luck so far.
Thanks for any help
54belair is offline   Reply With Quote
Old 11-29-2011, 07:24 PM   #2
john
member #16
john's Avatar
Re: Identifying a 12 bolt rear end
I dont know if my book has a misprint or not but it shows code HA as a 3.07:1 for 64-66 and a 3.73:1 for 67-69. Probably not too much help.
john is offline   Reply With Quote
Old 11-29-2011, 07:35 PM   #3
54belair
54belair's Avatar
I dont know John,
I was actually "thinking that it was 71 or later ?? due to the housing width and axle length.
The gears that were in the box withit are 2.83/1 (12 and 34)
If the guy had trouble keeping the posi together, I think I can see why with that ratio.
thanks for looking------- are you aware of a data dase with all these numbers in it?
Old 11-29-2011, 08:29 PM   #4
john
member #16
john's Avatar
Hard to say what you have, the 70 models and up used a three digit code.
The older two digit codes would have the shorter axles and housings. I get my info from the chevy pickup redbook 1946-1972 by Peter C Sessler.
