Old 11-30-2011, 04:35 PM   #1
xb9rguy
xb9rguy's Avatar
Tire size,rear end, and speedometer
So my speedometer is off by between 10-15 mph over 60mph. My tire size is 275/60/15 on all four corners and if I read right on another site that converts from original size to current I should only be about 1-2% off which unless i'm having a brain fart don't make sense as to why my speedo is so far off. So i'm wondering if someone in the past has changed out the gears in the rearend if that would make a difference and if so anybody have any idea what may be in it? Oh ya and it's in a 72 1/2 ton with 3 spd manual and sbc. Thanks for any help guys. I can't afford a gps speedo right now so I would like to figure out a cheap way to maybe get my speedo close to right.
Jeramy
CURRENTLY OWN,
72 c10 project/driver
2010 Kia Forte Koup SX daily driver
88 cherokee wheeler and dog hauler
2001 drz 400
Miss my 2004 firebolt (stock) and 2001 superhawk with a ton of modifications and many other previous vehicles.
xb9rguy is offline   Reply With Quote
Old 11-30-2011, 05:04 PM   #2
domeier
domeier's Avatar
Re: Tire size,rear end, and speedometer
Have your ladyfriend drive alongside you on the freeway and give you a thumbs-up when she hits 60. Mark your speedo with a grease pencil.
domeier is offline   Reply With Quote
Old 12-01-2011, 05:11 AM   #3
xb9rguy
xb9rguy's Avatar
I would but the last lady friend I had is the reason I'm broke now
Jeramy
CURRENTLY OWN,
2001 drz 400
Old 12-01-2011, 09:44 AM   #4
Andy4639
Old member
Andy4639's Avatar
Question Re: Tire size,rear end, and speedometer
The old speedo's in these trucks are a good guestment at best. Mine in my 71 never did read right. I used it up until back in August when I bought a GPS one. Have you got a GPS Garmin. If so use it on the map setting and it gives you speed. It's a easy way to check the truck.
The spring inside the speedo after 30 some years is wore out. I suggest a rebuilt one are a new one may or may not help you.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 11-30-2011, 05:53 PM   #5
Chris4x4Gill2
you can figure your rear end ratio:
Jack up rear end so that tires are off the ground.
Mark a line on the driveshaft, another on the tire.
Put in nuetral and rotate the tire 1 complete revolution, count the number of times the driveshaft turns.
"Lifetime" 72 C10 Project
Chris4x4Gill2 is offline   Reply With Quote
