12-01-2011, 10:49 AM | #1 |
cage question
can someone tell me if this is legal. would like to stay below window but would hate to one day be fast enough to need to get certified and have to redo truck again. thanks
12-01-2011, 12:28 PM | #2 |
It's Better With Nitro
Re: cage question
I cannot see inside the cab, but it is not legal for 10.00 ET, or quicker. Rearward bars from the main hoop have to be within 5" from the top of the main hoop, if you use tubing 1.5" diameter, or larger.
If you are planning on running at a NHRA track, be sure to invest in a rulebook.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes Last edited by vin63; 12-01-2011 at 12:47 PM. |
12-01-2011, 12:44 PM | #3 |
Re: cage question
You can get away with out the bars going to the back if the drivers area is built to the left hand steer roadster spec. What you end up with is a funny car cage in it and some more bars on the inside of the cab. A rule book is a good idea any time you are building a cage/ full chassis. Always decide how fast you may ever want to go in the vehicle and build to that spec. As you get into the faster classes the certifications change and the cage must meet an SFI spec.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
12-01-2011, 12:56 PM | #4 | |
Re: cage question
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
12-01-2011, 02:36 PM | #5 |
Re: cage question
What Vin63 said.....
12-02-2011, 04:57 AM | #6 |
Re: cage question
You have to ask yourself a simple question...Is my life worth having a proper cage to save me?. I know guys who run the below window style who race their trucks just once to see how fast it is. But if you get the bug and your time shows promise a Lexan window isn't such a big deal.
12-04-2011, 11:02 AM | #7 |
Re: cage question
Actually Tom Yancer had a Pro Stock truck that was built with the bars below the window. It was certified to run 7s, and he had the funny car cage in it.
12-04-2011, 12:33 PM | #8 |
Registered Truck Offender
Re: cage question
My 66 is built very similar and I can tell you Division 7 NHRA tech agrees with Vin63 and PGsigns,,,, Except that they will not allow anything 11.49 and quicker without the back bars, OR a funny car cage. Inside, outside, they don't care,, the tubes have to be in place. The rear supports must attach to the main hoop within 5" of the top of the hoop for a 'bar" or 12point "cage".
The 9.99 SFI chassis sticker get's real sticky and like metioned, There are a number of trucks with the Roadster / funny car cage 'inside' the cabin that meets the spec somehow. A couple of Yancers old truck chassis' are running in the sportsman classes around here in Az and Moggey is right,,, you can't see any back bars from the outside. But to the point of the original question,,, I'm suspecting this is a brand new build, or a pro-street show truck / driver (and a VERY nice job BTW). I see no ice tank for a intercooler, the tire dressing on the MT Sprotsman tires, no rock dents in the tubs,,,,,, I'm guessing (as always), but were not looking at a sub 11 second ride are we? I think the bar / back bars are going to be a issue for the 10.01 to 11.49 ET range
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. Last edited by Marv D; 12-04-2011 at 12:41 PM. |
12-04-2011, 02:29 PM | #9 | ||
Re: cage question
So, if prostreet1967 is going to build a roll cage for his truck, I'm under the assumption that he plans to go quick enough to warrant it. If not, building a roll cage is not a good idea.
12-04-2011, 06:41 PM | #10 |
Re: cage question
You could probably do some creative bending and get the tubes within 5 inches and still make it below the window. I dont want the bars on my truck to show either, and I dont want a funny car cage for a street driven truck. LOL Ill just have to see what they will allow.
12-04-2011, 09:44 PM | #11 | |
mini truck racer
Re: cage question
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
12-05-2011, 11:53 AM | #12 | |
Re: cage question
12-16-2011, 09:04 PM | #13 |
Re: cage question
hey what are yal using for solid mounts.
12-17-2011, 11:11 AM | #14 |
Re: cage question
as in solid engine mounts? They stress the side of the block in a high HP application and are typically used only to help control lateral movement.
Motor plates. Aluminum front plate and steel mid plate, poly mount on the rear of the trans is the typical.
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
12-18-2011, 12:33 AM | #15 |
60-66 Nut
Re: cage question
Depending on what style mounts you are running, I still have these for sale
http://www.67-72chevytrucks.com/vboa...d.php?t=478578
12-18-2011, 02:39 AM | #16 |
Re: cage question
was talking about body mounts sorry lol. gonna do cage and back half in next couple weeks. i heard im good with plates to cab but gonna tie into to rear frame so i wanted it to be stout as possible
12-19-2011, 11:03 PM | #17 |
Dino burner
Re: cage question
Just so that I understand the situation: you have a truck that was originally a full-frame truck, and someone has told you that you can just mount part of the cage to plates bolted to the floor?
I don't believe any sanctioning body, and for sure SFI, won't allow plates to hold any part of the cage unless it's a factory unitized body (aka "unibody") type of car. As already discussed, outriggers are required, and the roll cage tubing must pass through the sheet metal of the floor. |
12-18-2011, 10:18 AM | #18 |
Re: cage question
My cab floats on the stock rubber mounts,, I have seen builds like Regan's that isn't, but I took the rule book to heart and tied the cage to the frame with outriggers under the cab. With a backhalf, I'd think seriously about how you tie it all together. Your cutting the frame in half, then supporting it with the flimsy cab floor. Even with solid cab mounts I think your gonna see things flexing and breaking if it's making big power and hooking up.
12-19-2011, 02:37 PM | #19 |
Re: cage question
u have any pics of ur outriggers? ive seen some posted that dont look good. my truck is already back halfed but i havent tied cage to frame. going to redo backhalf in round tube so figured now would be the time to do it right.
12-19-2011, 03:18 PM | #20 |
mini truck racer
Re: cage question
Here is one of mine off my old blue luv . To the right is the rocker of the truck cab and to the left is the frame rail , behind it is the cab mount . It is dirty in this picture . This is also mild steel and not chrome moly . You can see the main hoop welded to the top of the out rigger so it can be fully welded . then the main hoop was raised into place with outrigger welded to it and it is then welded on 3 sides . The top of the outrigger is welded when the the hole is cut for the next bar to the top of the frame .The next bar in the cab are Kickers that run from the crotch of the seat belt bar and main hoop , then angle inward to the top of the frame rail to trianglulate tha connection . Clear as mud ?
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 Last edited by hotrod 80; 12-19-2011 at 03:29 PM. |
12-19-2011, 03:52 PM | #21 |
mini truck racer
Re: cage question
Here is a good illistration . The proportion of the bars are probably not to scale ,, but it gives you an idea of the triangle .
12-19-2011, 06:01 PM | #22 |
Re: cage question
Here are some I have found.
1969 C10, 2005 LLY Duramax, Wagler Competition built motor, Bullseye Power triple Turbo's, Rossler th400, Neal Chance Racing Converter, Danville Performance tunning. 8.3@168mph 1700+ HP |
12-20-2011, 10:45 PM | #23 |
Re: cage question
I will have to try and get some photos of my cage set up. My chassis man, Steve Tucker @ Southeast Hot Rods, cut throught the florr just inside of the inner rockers, and sank a
2x3 piece into the floor, and cut the cab floor supports out to accomodate the 2x3. He then attached the "rocker 2x3" to the frame rails with round chromoly as per sfi specs. Keep in mind that the structure must from a complete box under the floor. ( outer 2x3 to outside of framerail, inside frame to opposite inside frame to other 2x3. This must be done at rear of cab with main hoop, and front of cab with the front legs as well). I hope my word picture is clearer than mud. lol Paul |
12-21-2011, 07:52 AM | #24 | |
Re: cage question
Brett
01-04-2012, 11:18 PM | #25 | |
Re: cage question
The first photo is self explanatory, but you can see the 2x3 sank into the floor just inside of the rocker. The second photo just shows that the cage goes through the dash, and the 2x3 extends far enough forward to connect the front of the cage to. The third shows the 2x3 just under the carpet, with weld beads to the floor. The fourth shows the 2x3 from under the truck, here you can see it set into the cross cab braces, and the forward round tube that connects the 2x3 to the outside of the frame, even with the trans crossmember. Finally the fifth shows the round tube that connects the inside of the frame together at the rear of thw cab. Please note: the trans crossmember is able to be bolted in, and considered part of the structure, connecting the frame together at the front. I hope this is helpfull. Paul Last edited by kpeztruck; 01-04-2012 at 11:30 PM. |
