12-02-2011, 01:07 AM | #1 |
Dana 60 rear spindle nuts
What does the Dana 60 rear in my 68 3/4 ton have for spindle nuts? Are they are regular nut or are they the six prong?
From what I have put together Eaton HO52 and Corporate 14 bolts---six prong Dana 60s--regular nut that is like 2 9/16"? Is this correct? Just want to make sure I have the tool I will need when I do my brakes. Thanks
Daily-94 K2500 350 5spd extended cab longbox Project Red Velvet-68 C20 396-th400-AC-PS-PB-all original except for the 8 track and the gun rack. Build thread>>>>http://67-72chevytrucks.com/vboard/s...d.php?t=495881 My 01 TA and 88 Formula hide in the garage. :-) |
12-02-2011, 11:53 PM | #2 |
Re: Dana 60 rear spindle nuts
Anyone....
12-03-2011, 02:27 PM | #3 |
Here is what I use, lot better than beating a tab over.
http://www.speedwaymotors.com/Wide-5...-Nut,3759.html |
12-03-2011, 03:25 PM | #4 |
They have double nuts (2) on each side. 2 9/16 i believe. I can check further on the size if you need me too !
Bob p/s you can switch them out also if you want a different style there interchangeable new to old styles. i change modern 14 bolt ff rears to old double nut styles, i think older is better personally.....
I BELIEVE IN JOHN 3:16 |
