Old 12-04-2011, 01:52 PM   #1
CATrucks
Brownie Box in a C10?
So ive got a 292 with 3 sp and 3.08 gears in my 65 c10, looking for a way to get over drive. Been searching for a 3spd overdrive so I can get back my 3.73 gears, when I stumbled on the brownie boxes in the big trucks. Anyone put one in a half or 3/4 ton? Would it work? I think it would be pretty fricken awesome to have an auxillary tranny with a low and overdrive. What do you think?
CATrucks is offline   Reply With Quote
Old 12-04-2011, 05:26 PM   #2
pope
pope's Avatar
Re: Brownie Box in a C10?
I have seen a few pickups with the Brown Lipe 5531, which later became the Spicer 5831 installed. These were the smaller of the 3 speeds, there are a couple of different o/d ratios available. I believe that the brown lipe had the higher o/d ratio available of the two, would have to check my notes. They can be kinda nice to have especially for adding another O/D for long trips to keep your rpms down, as long as you are keeping it within the power band and not causing the engine to lug all of the time. I think that you would be happier with an O/D trans for driveability... just my 2 cents.. BTW is your truck a sb?
Where the hell did my coffee cup go?!!
pope is offline   Reply With Quote
Old 12-04-2011, 07:59 PM   #3
CATrucks
No, its a long fleetside. Yea finding an od trans will prob be cheaper and easier, just think the idea of an auxillary trans would be super cool, and If I ever find one, I might try it. Also with the brownie, do you shift while driving, or does it have to be stopped?
Old 12-04-2011, 10:58 PM   #4
pope
pope's Avatar
It is definately cool! I would have one in my 61 if I was able to squeeze it between the t -case and trans. You shift them on the fly, it is basically just another transmission that you can use to "split" the gears of your main transmission by shifting it through its gears while in each of your main speeds. You could also just leave it in O/D or any other gear and drive normally. They can be a blast to drive!
Old 12-05-2011, 02:04 AM   #5
Captainfab
60-66 Nut
Quite some time ago when I went to go look at some parts advertised for sale, I saw a truck being built where the guy had modified a second 3 speed trans to be used as an auxilariy trans. I don't remember any details of it other than there was a short driveshaft between the two. That and I thought it was pretty cool. I suppose if a guy had the means, and more time than money, something like that would be possible.
Old 04-19-2014, 11:55 PM   #6
Budman56
Budman56's Avatar
found one in the junk yard today and wonder what it was and what its worth?
MY 65 C20 BUILD
http://67-72chevytrucks.com/vboard/s...d.php?t=483346
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
Budman56 is offline   Reply With Quote
Old 04-20-2014, 09:30 AM   #7
Blue666
Not quite the cool factor but it seems an NV 4500 (2WD version) would also solve your needs. Would be easier to gather parts to install & repair. Just a thought.
Blue666 is offline   Reply With Quote
Old 04-20-2014, 10:22 AM   #8
Clyde65
Clyde65's Avatar
The nv4500 is a heavy duty 5speed manual, if your going to keep your 6, then I would look into an nv3500, they are good to 330ft lbs of torque.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 04-20-2014, 02:13 PM   #9
Blue666
True but lots of straight sixes were factory with the SM420 & SM465. The NV4500 has the low gear and an overdrive.
Old 04-20-2014, 10:41 AM   #10
66Submarine
66Submarine's Avatar
Budman56,
not real sure on price, but I might be interested in it myself. How much did they want for it? Looks a lot smaller than the Spicer 5831 that seems common, so shipping might not be quite as brutal from CA.
1965 C30 pickup 350/SM420/4.10's (daily driver) thread
1968 Impala 4 door sedan (future driver project) thread
66Submarine is offline   Reply With Quote
