Old 12-04-2011, 09:40 PM   #1
wibas
What radio to use?
My dash has been modifeid with hammer and chisel by someone to install a single din radio. I have a section from another dash that has good radio opening. I'm not sure if I want to do the surgery for the stock radio or if I want to do something different. What are you guys doing about radio? What model do you call a 1952GMC? Thanks
wibas is offline   Reply With Quote
Old 12-04-2011, 09:54 PM   #2
mr48chev
mr48chev's Avatar
Re: What radio to use?
My dash is going to be all changed around with a different dash with custom instrument panel so that doesn't help but I am planning on a swing down cover to hide the radio's face panel. I'd repair the dash, use a radio delete plate and then make a panel to hold the radio to go under the dash or maybe a console to go up in the roof to hold the radio up out of sight from most eyes.
Old 12-04-2011, 11:18 PM   #3
parkwood
parkwood's Avatar
This a dash in a '55 chevy using a custom auto sound radio... if you fix your dash it would look like this...
parkwood is offline   Reply With Quote
Old 12-05-2011, 02:24 AM   #4
Maximus
Maximus's Avatar
I think by his first post he has a 52' gmc, so his Advance Design dash would obviously be different.
To answer the original question I personally would restore it to the original form, but it completely depends on what your plans with your truck are, good luck!
Maximus is offline   Reply With Quote
Old 12-05-2011, 02:35 AM   #5
parkwood
parkwood's Avatar
Thanks Maximus, didn't see the '52 line... in that case i can only show you a '51 with the stock block off plate, but we still used the custom auto sound r.adio that you can hide anywhere
Old 12-05-2011, 06:03 AM   #6
54 jimmy
54 jimmy's Avatar
heres mine 54 gmc. had an extra speaker grill so i modifyed it to fit my radio.
There is nothing you can't fix with a BFH or a FIRE WRENCH.
1997 chevy k1500 ext cab z71 (daily driver) sold
1996 chevy k1500 reg cab 4x4(daily driver)totaled
2008jeep patriot (wife's daily driver
2008 chevy 1500 ext cab 4x4 sold
2011 chevy 1500 crew cab ltz (daily driver)
1996 chevy 1500 reg cab 4x4 project sold
2006 pontiac grand prix gxp (daily work commuter)
54 jimmy is offline   Reply With Quote
Old 12-06-2011, 09:00 PM   #7
BlueJeep
BlueJeep's Avatar
i plan to use my Droid for Pandora in my truck and run it through an amp that I'll mount under the seat.
Parkwood, this is off topic but that under dash unit is different than the "standard" vintage air unit, was that a custom order thing from V/A? I believe the standard has those cheap looking knobs.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 12-05-2011, 09:14 PM   #8
wibas
Hey Parkwood both those are good looking dashes. Is that a custom audio sound radio in the 55 dash? Does custom audio sound also make the hidden radio? Is that what you are using in the 51 dash? Thanks. Scott
Old 12-05-2011, 09:53 PM   #9
parkwood
parkwood's Avatar
Scott, yes both are from Custom Auto Sound.. the one in the '55 we also added a CD player behind the the seat.
On the '51 we put the unit under the seat and the face of the radio in the glove box.. the '51 came with an iPod hook up.
Old 12-05-2011, 10:06 PM   #10
booger1949
put the speaker face on a hinge an build a 2 inch box an install on the back side of the dash, i did mine 2 inchs so u have a place to put keys r the remote for the radio, when you close the speaker face nobody will see the radio, if u get a radio with a remote u can work it with the speaker face closed
booger1949 is offline   Reply With Quote
Old 12-05-2011, 10:16 PM   #11
S10Fan
Old Heap Driver
I went with XM radio in my 50. Made a backing plate out of some ABS plastic, bolted it in place where the radio knobs would go. the XM unit is held in place with double sided tape. An old Pioneer amp under the seat provides power to a pair of 6X9's behind the seat. A volume control from PAC (LC-1) keeps the tunes at the correct level. I can move the XM unit from car to car, I love it.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 12-05-2011, 10:26 PM   #12
booger1949
heres 2 pics that should give u an idea
Old 12-06-2011, 11:59 AM   #13
hopped up
hopped up's Avatar
i would go with a hinged radio delete plate to keep it looking factory . and put a radio with an ipod hookup behind it. nobody uses cds anymore.
hopped up is offline   Reply With Quote
Old 12-06-2011, 02:15 PM   #14
OrrieG
OrrieG's Avatar
Look at kustombrads thread, he made a slick opening center dash grille.
Old 12-06-2011, 06:40 PM   #15
S10Fan
Old Heap Driver
Link?
Bryan
Old 12-06-2011, 09:33 PM   #16
OrrieG
OrrieG's Avatar
Originally Posted by S10Fan View Post
Link?
Search function will find it but here is a link that shows the door. Earlier in the thread he has more detail.
http://67-72chevytrucks.com/vboard/s...&postcount=403
Old 12-06-2011, 09:44 PM   #17
S10Fan
Old Heap Driver
Tried searching, came up empty handed, thanks for the link!
Bryan
Old 12-06-2011, 11:08 PM   #18
renegade6
I think it depends what look you are going for. If you want to go custom, I would fill and smooth it otherwise use the delete plate.
Brandon
63 Biscayne https://www.pro-touring.com/threads/90718-63-Biscayne
57 Chevy Truck (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=321380
72 K20 Long bed stepside (wife's)
72 K20 Long bed 396 (flip or keep...?)
The latest build: http://67-72chevytrucks.com/vboard/s...76#post8438476
renegade6 is offline   Reply With Quote
Old 12-07-2011, 01:44 AM   #19
bfink
gear drive , big solid-lifter cam and flowmasters turned down under the bed .....i dont think im even gonna put a radio in !
bfink is offline   Reply With Quote
Old 12-07-2011, 10:37 AM   #20
wibas
Hey guys thanks for the input!
Old 12-07-2011, 11:37 AM   #21
solidaxel
solidaxel's Avatar
............ YES, that is the SAME one I used in both of my trucks !!!
Except for the 4" megs I used for exhaust tips!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 12-17-2011, 12:44 AM   #22
wibas
Thanks for the input. I patched the damage with a piece from anothe ND dash. Now I need to find a suitable radio. After doing some searching I wished I would have smoothed the radio hole. I have not found a suitable radio to fit the original opening. Any ideas on what brand to use???????
