[><]Sofa King Dirty 4x4[><]
Truck bed roll bars
I'm tryin to get one for my stepside but the stepside roll bars are a little harder to come by but post up some pics
00' Chevy Silverado 1500 z71 33"s 3" lift 5-speed Past trucks 85' Chevy C10 Step side 388 stroker 33" bfg a/t's holley 670cfm world product heads 14.80@92mph 92' S10/Tahoe sbc swap |
Re: Truck bed roll bars
Do you mean "light bar" or "roll bar"?
Almost all the "roll bars" I see are just "light bars" meant to hold lights, not to protect in a rollover. Most of these are light tubing and will crush in a rollover. Rollover protection requires substantial strength and design. I would be very interested in true rollbars for trucks that mount in the bed.
74 Longbed 76 Shortbed 87 Shortbed 66 Corvair Turbo 62 Chevy II Turbo 6 |
#3 | |
The One And Only !!!
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! ![]() The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
You are correct and I know that, just brain fade not being specific. What I meant was one that was outside the cab.
Those light bars just mount to the bed floor and are thin pipe like exhaust tubing.
have a local weld shop make one. Simple welding and bending. shouldn't be too much.
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ] ![]() 1999 k3500 crew cab dually 6.5tdi/4l80e |
I bet you could pull an rops off an old tractor and make it work
That is a stack of light bars and I would not want to be upside down and hope that kept the roof off my head.
If they didn't collapse, the bed floor would not hold up. Those are attached to SHEET METAL not the frame, even if they are better than exhaust pipe.
#9 | |
Redneck Customs Bumpers, IA
sorry I don't have pics of one for a stepside but I want some of these complaners to know that the chrome rollbar my father purchased in 83 for the 78 gmc he had has 1/4" walls and came with kickers that bolted under the box from the frame to the rollbar in the front and spacers that went under the bed from the 2 bars that ran between the fenders to the frame back there, the bar itself is still around but my brother forgot to pull the kickers when he sold the 87 a year ago that he installed the bar in, needless to say my dad was a little hot bout that, and also the black dual tube I have is 1/4" wall on the 2 front hoops and between 1/8 and 3/16 wall on the bars that run between the fenders, I plan on modifying my bar to fit a stepside once I get the box built for my 85 K20 "Clifford"
Overkill is under rated, Redneck Customs Truck Club Hudson, IA "Clifford" 83 Chevy K20 4x4, Mudder 7" lift rolling 44's "Basterd Child" 86 Chevy K30 4x4 crue cab Dule, 7.3l international WIP '00 ex-cab Silverado 4x4 DD I hate red trucks but you can't tell by looking at what I own |
#11 | |
Atleast someone understands, get pics when you do end up mounting the bar
Not the first time I seen people talk crap about them, not sure why they do. Regardless of how worthless they are, they are better then nothing at all and most people only use them for light bars anyways.
I have one on my step, I'll get some pics. I also welded plates to the cross 'beams' under the bed so that the ROLL bar would bolt to something more solid then just the wood floor. Mine came with the truck when I bought it, the main bar is one piece. I looked into a new one and all i could find was multi piece ones, they looked like junk. Just dont get a multi piece one. These dont really show the bar in detail, not sure what ur wanting to see but this is what I already have. I will take some pics of how I mounted it when I rebuilt the bed. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
Sick ass truck there, thats what i want mine to look like when im done, what size lift?
35's with 4" Thats what the truck looked like when I bought it.
Believe it or not I worked on it for another 5 months after I bought it. Rebuilt everything from the body down, rebuilt the bed, rewired the whole truck, and did lots of little other things. It now has a 6" with the same tires, now the suspension can actually flex. last two are after I rebuilt the bed. I'll get more pics this weekend. Im not big on taking pics during a build, rather build, but did lots of things that could save others lots of trial and error. So should do a build thread, help others like they have helped me with their threads. Just that all the pics will be after the fact. |
#15 | |
Thats the lift i want, how was it with the 4" did it hit anywhere? and i want to do most to my truck like you explained you did to yours, i need to rewire and such. also was the tool box homemade?
#16 | |
Conversion Truck Addicted
life has been saved in the monster truck industri back in the day most didnt sport a rollcage before 85-86
Wassent sporting a roll cage just a smitty build rollbar
Thomas Quote:
#17 |
Charlie Daniels w/ a Tq Wrench
Light bar that used to be on my 78, not stepside though.
ΜΟΛΩΝ ΛΑΒΕ 67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works69 K5 Blazer-Family Beach Cruiser Project 78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s |
#18 |
#19 |
with 4" the 35x12.5s didnt hit anywhere during normal driving and some minor flexing, but I never really tried it out. Bought the truck drove a little around town and then tore it down. Now with the 6" thats made to flex and 1" body lift on cab only the front tires will hit at full flex and turned all the way. Bed does not have a lift and tires wont hit. Rear springs are 56" vs stock 52", so they are really flexy, plus the rear springs are only 2" lift = more flexy vs 6" lift spring, the other 4" are from a shackle flip.
Here are some pics, I would guess this is about the limit of the 6" lift, this is with 1" body lift on cab only and 35"s. The truck was still unfinished here so some stuff may look incomplete, I had just got it drivable again and this was the closest place that I could chance driving to so I could test the suspension. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
#20 |
That truck is beautiful thanks for sharing all the pics
#21 |
Thanks, Oh, and the tool box I got from tractor supply, they are a chain of stores I dont know if there is one near u but check on line for the nearest store.
Verify the dimensions but i think this is it. http://www.tractorsupply.com/tractor...silver-1091436 |
#22 |
![]() Join Date: Aug 2011
Don't see them around much anymore, bought this for my dad's truck back in 1977, still on there today. Never been used!!!
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison |
#23 |
Here is the bar that came with my stepside, have not decided if it goes back on or not. Itīs not in one piece, legs are loose, if I put it back on it will be welded solid. It was rattling all over the back before.
Tom.______________________________________ The fleet: 2007 BMW 530xi M (daily driver) 1986 C-10 Stepside (project "my time") 1992 Corvette cab (summer time daily driver) 1969 Cadilac DeVille Cab ("it just need some paint") |
#24 |
78K & 79C Jimmys
lol seen this
like a deer with huge antlers must be a roll bar there's no lights on it lol
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
#25 |
