Inside Door Panel Screws HELP
Anyone have an easy way or a good way on how to get the Inside Door Panel Screws out of a rusty door? I have tried an impact hammer and penetrating fluid to no avail.
Re: Inside Door Panel Screws HELP
ive had some break. i drilled a hole in the center of the screw and used an extractor. let the penetrating oil sit for a bit.
good luck.
'66 chevy lwb c10 '65 chevy lwb c20 |
You may have to resort to welding a nut to the top of the screw so you can use a socket to get some leverage on it. We've had to do that MANY times on old rusty stuff.
Or use the "magic dust", as my dad likes to call it, Aerokroil. That stuff works amazingly well. It's expensive, but it works so well the cost is worth it. -Aaron |
#4 | |
60-66 Nut
X2......
Extractor on almost all of my door panel screws
Posted via Mobile Device |
the panel screws are a # 3 phillips, most high end screwdrivers ( snap on matco etc ) have a hex shank at the end of the blade next to the handle so you can put a wrench on it for leverage. I always put the screwdriver on the screw the give it a few medium blows to loosen it up and apply pressure inwards to hold the tool firmly into the screw and using the wrench give it a twist. Repeat giving it a few blows if necessary. Never had a screw I could remove using this technique. Be sure and use a #3 phillips, you would be suprised how must the right size screwdriver makes
1965 long bed ( grandpas old truck ) 1964 long bed BBW Custom Cab 1966 Short stepside 1964 long bed 1965 long bed Custom Cab, factory air, V-8, powerglide |
Applying heat with a torch does wonders, although you will likeley damage the paint. I have used the number three phillips bit in a electric impact wrench with great success. You lean into it with all your weight so it can't spin out and bump the impact. Also have had luck with a plain old breaker bar instaed of the impact.
I don't think it is possible with only a screwdriver. Use neverseez when you put things bacl together. |
![]() Join Date: Nov 2007
hammer impact and valve grinding compound on the tip of the # 3 driver.
I can vouch for Aerokroil mentioned by Crash'd above. Crazy expensive, I think I paid 14 bucks for a 10oz. can but It works better then any other penetrating oil I have ever used. It has never not worked for me.
Mark ![]() '63 C10 short step |
Stirrer of the Pot
I had to do this just this weekend, I used penetrating lube (giggle), a lot of my muscle, and some creative tapping and prying to break the bond between the panel and the screw. I was surprised, but they all came off the '62 and now my '61 is that much more complete. lol
i just drilled them out like you would a rivet and go from there it took me a wopping 5 mins then i put c-clip nuts on them and voila
Krazy Texan My Trucks are made with Wrenches not Chop Sticks 1967 GMC 3/4 ton "Johnny Cash" 1990 v1500 suburban 1967 Ford f100 Swb 4x4 "green bean" GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO |
